Lightning cam questions
Old Oct 18, 2007 | 04:29 PM
kellar's Avatar
kellar
I am looking in the Federal Mogul Sealed Power catalog at non-roller 351 cams and see something that confuses me a little. According to them in 93 the Lightning had a smaller cam than the other 351s.
351 HO (4bbl) and EFI until 93
Lift- .278/.283
Dur- 206/221
93-95 Lightning/ 82-85 Mustang
Lift- .260/.278
Dur- 198/208
Can anybody tell me if this is correct? If it is- why such a small cam in the Lightning?
Old Oct 18, 2007 | 05:19 PM
Conanski's Avatar
Conanski
That's a bit mixed up. The regular truck motor(2bbl carb and EFI) had the wimpy little cam, the 351HO and the Lightning had cams very similar to the 5.0HO but flat tappet. If you are building something for a truck forget all of them and get a Comp Cams 35-255-5.
Old Oct 18, 2007 | 05:39 PM
kellar's Avatar
kellar
The catalog shows the 2bbl 351:
Lift- .260/.260
Dur- 195/195
I have a cam from a 85 Mustang HO (non roller) which is supposed to be the same cam as the Lightning (may not actually be??). But I think I am going to buy the 351 HO 4bbl cam for my 351 which is currently 2bbl but will be EFI in my Mustang. Will the 351 HO cam work properly with EFI? It seems like it'd provide plenty of power especially with 1.7 rockers.
Old Oct 18, 2007 | 09:31 PM
Conanski's Avatar
Conanski
Yes, the specs say it will work, but it still leaves plenty on the table. The Comp cam I mentioned above has more lift and more importantly is a dual pattern biased to the exhaust where the ford heads need it. The motor will respond to incresed lift all the way to 1/2", and those heads are more of a bottleneck on the 5.8 than the 5.0, so you need to let it breath. It won't cost you low rpm TQ either, it's still much shorter duration than the B303 you have in the car.
Old Oct 18, 2007 | 09:40 PM
Mr. M's Avatar
Mr. M
Comp 35-355-5 is a vast improvement... if it is in fact for a half ton pickup application.
The ford alphabet cams leave a lot to be desired for truck applications. A little die grinder work on the heads (especially on the exhaust side) will go a long way for this build as well.
Good Luck,
Mike
Old Oct 19, 2007 | 06:28 AM
kellar's Avatar
kellar
How would the 35-255-5 respond to 1.7 rockers?
Old Oct 19, 2007 | 08:29 AM
Conanski's Avatar
Conanski
Same as any other cam, more lift. It would go from 0.478/0.485" to 0.506/0.515"
Old Oct 19, 2007 | 07:58 PM
kellar's Avatar
kellar
I am going to sell my B303 and I will likely get the Comp Cam because it has the wide power range that I am looking for. I came across another cam that may be interesting. It is the Ford Racing 6250-A332. It also has the wide power range and I think it may be similar to the Comp.
Lift- .472/.496
Dur- 214/224- 290/300
Old Oct 24, 2007 | 10:09 AM
Kemicalburns's Avatar
Kemicalburns
whats the lobe seperation of that ford racing cam you just found?
Old Oct 24, 2007 | 11:28 AM
kellar's Avatar
kellar
The lobe seperation is 112. If it will work with EFI I will probably buy it. From Keystone that cam is $150 cheaper than the Comp.
Old Oct 24, 2007 | 02:43 PM
Kemicalburns
no that will not work. you need a cam with a 114 lobe seperation. thats why we said to run the 35-255-5
kellar
Jan 23, 2008 09:34 PM
bossed
Jun 28, 2007 11:14 PM
marioc956
Nov 3, 2006 09:58 PM
broncobillybob
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 23, 2005 11:40 PM
Spdalit
Dec 14, 2002 10:30 AM
