Charging problems
Old Oct 18, 2007 | 08:47 AM
t.Rowley's Avatar
t.Rowley
Charging problems
Ok so I know this issue has probably been addressed before and electrical problems are hard to figure out but here it goes. My truck a 1978 F-150 4X4, 460 ci, will run for about 4 days and then the battery will die. I will jump it and it will run again fine and then die. I have replaced the regulator, and alternator. The person before me has a massive stereo system in it that he just cliped the wires and took when he sold it. I took all the exposed wires out and put in an 8 track. Any ideas as to this problem. I have taken the positive cable off and it will run, battery is reading 14.2 volts when running.
Old Oct 18, 2007 | 09:23 AM
1975Ford's Avatar
1975Ford
Remove and clean all battery connectio at Battery.
Remove, Clean and Check battery cable connections where the cable end mounts on engine.
Check and clean the battery cable connections at starter relay (aka starter solenoid).
Check the battery cables for starter relay to starter for good connections.
"With voltage meter connected to battery."
Wiggle wires from alternator to voltage regulator while inspecting voltage meter.
Wiggle wires from alternator to starter relay while inspecting voltage meter.
Inspect these wires for cracks or breaks or frayed wires.
Is the battery losing power after trucks being parked for some time?
Old Oct 18, 2007 | 09:31 AM
t.Rowley's Avatar
t.Rowley
It has new cables that I just put in and I also replaced the starter relay. Trying to just go through and replace most things anyway, just for reasurance. All the connections are tight, atleast they appear to be.
Old Oct 18, 2007 | 09:35 AM
merlynr's Avatar
merlynr
Sounds like an ignition problem from your explanation. Dies while running and
won't rrestart? Will it crank over?
edit: I guess I'm confused after rereading. Jump starts ok?
Old Oct 18, 2007 | 09:37 AM
t.Rowley's Avatar
t.Rowley
It will restart, run fine for about 4 to 5 days and then it will be dead again. Jump it and the process will start all over again. Could it just be a bad battery
Old Oct 18, 2007 | 09:47 AM
merlynr's Avatar
merlynr
Could be a bad battery. Needs to be load tested. Could also be a battery drain while sitting.
Old Oct 18, 2007 | 09:54 AM
t.Rowley's Avatar
t.Rowley
i have noticed if i run the radio, heater and lights the battery will die faster, but as soon as jump start it again it will be fine for a few days.
Old Oct 18, 2007 | 09:56 AM
1975Ford's Avatar
1975Ford
A fast way to test a battery and/ or a bad connection.
Is to remove coil wire at distributor, turn on head lights and then crank over starter.
If lights go very dim, or battery loses power quickly, then battery is probably gone.
Recharge battery and then give a load test.
Next Time, When the truck engine doesn't want to start.
Connect the voltage meter and check voltage a battery.
With engine running, head lights on, radio on, and other power accessory on,
Check the voltage of the charging system at battery
Old Oct 18, 2007 | 10:04 AM
t.Rowley's Avatar
t.Rowley
I have done this. The battery was down around 8.1 volts. jump started the truck and the battery was reading 14.2 with the truck running.
Old Oct 18, 2007 | 11:02 AM
1975Ford's Avatar
1975Ford
Possibility of two causes...
1. Bad battery - give battery a load test.
2. Power is being drawn will engine and truck are parked and not running.
Give electrical system an electrical test for power being drawn while engine and truck are not running.
Old Oct 18, 2007 | 11:55 AM
Mil1ion's Avatar
Mil1ion
Bad battery ..get it tested.They develop shorts inside themselves and discharge.
and NEVER EVER remove a battery cable with the engine running.
I am still trying to find out why people do this ?
It causes them to buy new alternators.
FordPerf300
Apr 24, 2022 10:18 PM
smitty_89
Jun 21, 2013 12:17 AM
Taz79
Aug 4, 2009 09:17 AM
*2fords*
Jun 16, 2009 09:25 PM
luv2bowhunt
Feb 16, 2004 10:09 PM
