stroker?
Old Nov 21, 2000 | 05:16 PM
nickc84's Avatar
nickc84
stroker?
69man,
Thanks man I appreciate you replying and informing me correctly.
thanks man
nick
Old Nov 24, 2000 | 12:37 PM
fordification's Avatar
fordification
stroker?
69man is right, by increasing the stroke throw, the displacement of the engine will increase. On a more technical note, this is achieved by increasing the distance between the centerline of the crankshaft to the centerline of the connecting rod journal. To compensate for the extra length the piston travels up and down the bore, and to prevent the piston from contacting the cylinder head, short aftermarket rods and a shallower piston with the wrist pin relocated closer to the rings to lower the pistons TDC position.
Old Nov 24, 2000 | 10:25 PM
390fe's Avatar
390fe
stroker?
May 10, 2017 07:33 PM
393STROKER
21
Nov 15, 2008 09:33 PM
ford390gashog
37
Dec 29, 2007 05:55 AM
67 428 Fairlane Ranchero
Jul 17, 2003 09:42 PM
big_country_ch19
Dec 20, 2002 07:46 PM
