Electronic ignition 391
Old Dec 14, 2000 | 01:38 PM
freesaw's Avatar
freesaw
I have a 391 in a L700 truck and would like to convert it to electonic ignition. Were can I get information on this conversion, wiring diagrams distributer etc.
Old Dec 14, 2000 | 04:33 PM
dinosaurfan's Avatar
dinosaurfan
Free- there used to be available from ford a conversion kit that let you put duraspark guts in a points dist. if you can't find that you will need a 391 or 361 FT duraspark distributer from a salvage yard. I would recommend the standard motors LX101 control box rather than the ford module, less wires to hook up. You must use an FT distributer because the FE units use a smaller diameter shaft. Some guys like the Pertronixs unit for ease of install. DF
Old Dec 14, 2000 | 10:59 PM
freesaw's Avatar
freesaw
Dino thanks for the info, I didn't know ford made a duraspark for a 391. Pertronix sounds like the way to go but they don't list a kit for my distributor, mine is a 1978 model. thanks again.
Old Dec 19, 2000 | 07:06 PM
390fe's Avatar
390fe
Try comparing your distributor with a regular points unit for an FE. What, if any, are the differences? I'll bet they're just the same and that the Pertronics unit will fit your FT. I'm obviously not positive it'll fit, but it would seem highly likely.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Dec 20, 2000 | 04:28 PM
rusty68's Avatar
rusty68
i just posted these links over on the old truck forum, but guess it won't hurt to cross-post...
if, as i've been told, the upper half of all v-8 distributors are the same, you should be able to put in a ford electronic ignition without too much trouble. i'm going to the junkyard to pull parts for my upgrade this week.
the second link shows you how to upgrade a points distributor to electronic.
http://web.p3.net/~shoman/duraspark.htm
http://rfaulconer.home.mindspring.com/duraspark/eec.htm
Old Dec 20, 2000 | 04:35 PM
BB's Avatar
BB
Here’s another link for the conversion: http://www.geocities.com/MotorCity/Shop/6755/conversion.html
Old Dec 23, 2000 | 10:37 PM
karljay's Avatar
karljay
ac7880
24
Dec 1, 2021 09:20 PM
mikeelikee
Aug 2, 2020 04:29 PM
1972 c 750 391
Engine Swaps
Apr 19, 2008 05:56 AM
herman391
1983 - 2012 Ranger & B-Series
May 27, 2007 06:00 PM
Ford391
May 29, 2004 04:06 PM
