Door Chime
Old May 27, 2007 | 01:24 PM
herman391's Avatar
herman391
Door Chime
Is there any way to turn off that annoying chime that goes off when the key is the ignition and the door is open? I have a 2003 Ranger Edge 3.0L. Thanks
Old May 27, 2007 | 01:56 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
There is a little tab on the ignition tumbler assembly. When the key is in the ignition it bends this tab, pressing it up against a contact to indicate the key is in the ignition.
You can probably remove the tumbler, and bend the part around so they never touch.. this should take care of the chime.. BUT I don't know what it's going to do as far as the PATS and all that.
Good luck.
Old May 27, 2007 | 02:17 PM
Benaghetto's Avatar
Benaghetto
Depending on where the source of the noise is you might be able to simply unplug the chimer. I did this in my truck, granted its a 94, but it unplugged and no more chime!
Old May 27, 2007 | 06:00 PM
RangerPilot's Avatar
RangerPilot
Should be much the same for your 2003:
Under the dash at the firewall is a large plug with a lot of wires under it. Look for a red/pink wire. With the door open ***** this wire and check for power. Should be basically 0 volts.
Put the key in the ignition and test it again. Should be 12V. If so, cut wire and tape off.
This will remove the chime when the door is open and key is in the ignition, but keep the chime functional other times, for example if you leave the headlights on.
rhino_160
26
Jul 2, 2011 10:29 PM
rocky3539
2004 - 2008 F150
May 17, 2008 10:23 AM
truckalpers
1997 - 2003 F150
Nov 2, 2005 03:00 PM
drewg123
Sep 12, 2005 12:17 PM
djohn
1997 - 2003 F150
Nov 26, 2003 01:36 PM
