Dana 35 TTB Issues
Old Oct 17, 2007 | 06:27 AM
HogTied's Avatar
HogTied
Thumbs down Dana 35 TTB Issues
Here lately, my 93 Ranger (138k miles) has been making alot of noise from the front end. After I drive it a while and it warms up, the front end really makes loud, deep squeaking and popping sounds when you turn it. Also, over small pavement irregularities and over bouncy roads, it just squeaks and pops the whole time. Also, if are turning left and hit a pothole, it makes a big CLUNK that you can feel in the steering wheel.
I have checked the radius arm bushings and they are fine. What else could it be?
Old Oct 17, 2007 | 08:23 AM
tbolt 460's Avatar
tbolt 460
ball joints
Old Oct 17, 2007 | 10:00 AM
blue beast's Avatar
blue beast
Wrap some electrical tape around your driveshaft then tie it to the frame go for a drive
in 2wd and if the tape is ripped, one of the hubs could be engaged or there is a lot of
parasitic drag in the system. Whens the last time the bearings got grease?
Old Oct 17, 2007 | 07:13 PM
DesertStorm's Avatar
DesertStorm
x2 ball joints
or it could be the wheel bearings/bearing locknuts. Mine did the same a while back both spindle nuts were cracked and the ball joints were worn.
Old Oct 17, 2007 | 07:18 PM
jv42287's Avatar
jv42287
I agree with the wheel bearings. my 97 (121000mi) was making a loud noise as you explain and popped occasionally too. I did the bearings and brakes while i was there and it stopped. Has never sounded so quiet before.
Old Oct 17, 2007 | 09:05 PM
Peter94's Avatar
Peter94
Make sure you remedy the problem. When it starts to quiet down is usually when things are beyond repair.
Mattman81
Jan 17, 2017 12:38 AM
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
pastelsand
Aug 29, 2014 11:09 PM
AkF250HD
Aug 7, 2013 06:31 PM
spdmpo
13
May 28, 2010 10:17 PM
