What is 0541 code?
Old Oct 15, 2007 | 12:30 PM
RDC F250 7.3's Avatar
RDC F250 7.3
What is 0541 code?
Scanned with a Bully Dog
Old Oct 15, 2007 | 12:41 PM
rugermack's Avatar
rugermack
My list says "Manf Intake Air Heater Circuit Low",
Old Oct 15, 2007 | 12:49 PM
F250_'s Avatar
F250_
RDC... have you eliminated the AIH? If so, you may want to get the item in the link below to eliminate the code.
http://www.puredieselpower.com/catal...541-p-109.html
Old Oct 15, 2007 | 12:55 PM
rugermack's Avatar
rugermack
Thanks F250, I didn't know I needed that. I haven't checked my codes in a while but, I bet that ones there.
Old Oct 15, 2007 | 01:02 PM
smoky_diesel's Avatar
smoky_diesel
http://www.puredieselpower.com/catalog/73l-powerstroke-air-intake-heater-plug-code-eliminator-p0541-p-109.html
Anyone know what's inside that thing? Probally just a resistor, can someone ohm one out and tell us what the value is?
How does the puter do its KOEO check? does it look for a change in the temp sensor in the CAC manifold? Or does that other wire on the relay output termial go back to the puter?
Old Oct 15, 2007 | 01:05 PM
RDC F250 7.3
Thanks,
How about a "1000" code
Old Oct 15, 2007 | 01:09 PM
F250_'s Avatar
F250_
You can run wihtout it, like I've been doing since January of this year. Won't cause any problems if you don't have it. I'm waiting until I either order something else form them or someone identifies how its made so I can make my own.
Old Oct 15, 2007 | 02:24 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by RDC F250 7.3
Thanks,
p1000= Monitor checks not complete more driving required.
go drive it a little more.
did you find your boost leak?
Old Oct 15, 2007 | 02:47 PM
rugermack's Avatar
rugermack
F250, do you know were the wire connects to ? By the size of the wire its looks like it might go from AIH relay to ?
Old Oct 15, 2007 | 03:17 PM
F250_'s Avatar
F250_
AIH relay to ground on the Air Circulation System bracket. Instructions will come with it, and are linked below.
http://www.puredieselpower.com/Tech/Dfuser%20P0541%20Code%20Eliminator%202004-12-27.pdf
Old Oct 15, 2007 | 03:38 PM
rugermack's Avatar
rugermack
F250, it looks like the black wire off AIH could be used to ground relay, with install of larger conector, Instead of a whole new wire going from ground to AIH relay. Actually I'm not looking at my truck right now so wire would probably be too short to reach relay. But would work if it was long enough.
Old Oct 15, 2007 | 03:42 PM
F250_'s Avatar
F250_
Like they say, though... "it's more than just a wire", whatever that means.
Old Oct 15, 2007 | 04:01 PM
rugermack's Avatar
rugermack
The only other thing it could be is a fusilbe link,just incase their was an over current it would burn thru instead of taking out a fuse.
Old Oct 15, 2007 | 04:05 PM
bdrummonds's Avatar
bdrummonds
Mine is wrapped with electrical tape and is in the valley ziptied so it cant "accidentley" touch something
Old Oct 15, 2007 | 04:19 PM
rugermack's Avatar
rugermack
We were not talking about the red hot wire that was originally on relay, we were talking about the new blue wire and possible using the old black wire to ground the relay. Instead of new blue wire. Or atleast I was questioning using the old black, instaed of the new blue wire.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
