390 piston rings
Old Mar 28, 2001 | 11:02 PM
phaffy12's Avatar
phaffy12
390 piston rings
As I understand, the 390 has a bore diameter of 4.050". Does this mean that replacement rings should be of 4.000" diameter? Thanks for any help.
Old Mar 29, 2001 | 03:25 PM
dinosaurfan's Avatar
dinosaurfan
390 piston rings
Matt, yes your 390 has a 4.050 bore and that is the size your rings need to be, 4.050 DF
Old Mar 29, 2001 | 11:22 PM
phaffy12's Avatar
phaffy12
390 piston rings
Thanks for setting things straight. I had thought the rings would match the bore diameter, but when searching JEG's for new rings there were none for a 4.050" bore which certainly confused me.
Old Mar 30, 2001 | 11:12 AM
buzzard's Avatar
buzzard
390 piston rings
Matt, DF is absolutely correct about the bore diameter of a STOCK 390. Most of these old motors have been bored at one time or another so make sure you know what you have before ordering any parts. If your motor has been bored, the tops of the pistons should have something like .030, .040, etc stamped on them.
Old Mar 30, 2001 | 01:13 PM
chilly390's Avatar
chilly390
390 piston rings
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 21, 2019 01:40 PM
bigblockford_390
Mar 1, 2015 09:24 PM
HellRaiser46
1947 and Older Ford Trucks
Jul 11, 2014 02:30 AM
Cougar54
42
Mar 23, 2014 01:41 PM
