my 1st engine build
Old Oct 14, 2007 | 09:37 PM
pintoches's Avatar
pintoches
my 1st engine build
well I'm starting my first engine build I chose a 289 because it will fit in most of the ford cars i like. not sure if I'm going to keep it a 289 or make it a 302.
my block casting # are
C6AE-6015-C
makes it a 65-68 289
6 bolt bell housing
bore 4.00
deck 8.206
head casting #
C80E
MAKES THEM
68 289 OR 302
63.CC
valve diameter
in 1.67"
exh1.45
I finished all the tear down to day hope to sent to the shop on Tuesday.
from there i will post what i find.
Old Oct 24, 2007 | 07:04 PM
pintoches's Avatar
pintoches
The 289 was crap.
The block is good it has no cracks. it however has to be bored over a least .30
The crank is bad the 2nd and 4th mains are bad
Rods have to be resized.
Well since the crank and rods need repair, i will get a 302 crank and rods.
For now I will wait to see if some thing comes along.
Old Oct 25, 2007 | 12:11 AM
Beanscoot's Avatar
Beanscoot
Those problems you described are not unusual to find when rebuilding an engine, remachining all those components is fairly normal.
Old Oct 25, 2007 | 03:49 AM
Sport45's Avatar
Sport45
If you have to get a crank anyway, why not consider a stroker kit? I know a 302 can be taken up to 347 cubic inches. I'm not sure what you can do with a 289. Lut us know how it turns out.
Old Oct 25, 2007 | 12:38 PM
BEWOLD's Avatar
BEWOLD
Just a note, I think the 68 302 and 289 heads were different in ccs. 68 289 were low compression 63cc approx, and 302s were around 53cc. recomend 331 stroker, theyre more cost effective and increased longevity over a 347.
Old Oct 25, 2007 | 11:10 PM
pintoches's Avatar
pintoches
i have the 63cc heads the casting #C80E are for the 289 or 302 in 68
I think i have a lead on a 5.0 EFI donner car. for $300
Old Oct 26, 2007 | 12:02 AM
BEWOLD's Avatar
BEWOLD
Ok, just letting you know. There is more to the casting # as in C80E-L. Because the C80E-F 302 heads are 53cc with larger valves. (didnt want you to miss out if you werent positive on what you had). You have the low comp 2 barrel heads.
Old Oct 26, 2007 | 12:03 AM
RacinNdrummin's Avatar
RacinNdrummin
The 289 heads were the same as the 2v 302 heads aside from the valve diameter. The 302 4v heads were 53cc's.
