E7TE 351 heads on 302
Old Oct 13, 2007 | 04:19 PM
MintFord's Avatar
MintFord
I picked up some E7TE heads from a 351 to use on the 302 that I'm rebuilding. Its my first engine rebuild. The machine shop resurfaced the deck on the 302, but I don't know how much they took off. I'm using flat top pistons. Should I be concerned about the valves touching the pistons? Its a D0AE block with stock cam. Thanks.
Old Oct 13, 2007 | 06:40 PM
baddad457's Avatar
baddad457
E7's also came on 302's in 87-97 trucks and vans,and the 87-95 Mustang 5.0 PLUS the 87-up Lincoln Mark VII 5.0, same heads only difference is the larger head bolt holes on the 351's, you'll need the step washers they sell for installing aluminum heads on 302's. Your piston to valve clearance is no way close to matter with a stock cam. If the block was milled any more than .030, you'll have the intake fitment to worry about, not the valve clearance.
Old Oct 13, 2007 | 06:51 PM
MintFord's Avatar
MintFord
I did ask about the intake fitting when I picked it up. They said it would be ok, said just a small amount taken off the deck. Lets hope they knew what they were talking about. I didn't even notice the head bolt difference. Guess I'll look for some step washers. Thanks baddad!
Old Oct 13, 2007 | 06:52 PM
baddad457's Avatar
baddad457
Summit and Jegs sell the washers as will any other place that sells aluminum heads for Fords. Summit part number EDL-9680 for the Edelbrock washers--$48. I did the same thing with one pair of E7's that I'd bought in the junkyard, they turned out to be 351 E7TE heads too.
Old Oct 13, 2007 | 10:39 PM
Conanski's Avatar
Conanski
Why would anybody rebuild a motor with the stock cam?
Old Oct 14, 2007 | 01:35 AM
MintFord's Avatar
MintFord
I have too many projects going now, so I'm on a tight budget, which means I'm using the stock throttle body fuel injection system. Computer wont add enough fuel to support a better cam. I'm looking to go to multipoint, mass-air and better cam in the future. The motor is going in a little fox-body '84 marquis, so it ought to push it around pretty good anyway. Anything is an improvement over that lousy 3.8L V6. I ordered the edelbrock step washer (bolt bushing as they call them) set from autozone tonight.
Old Oct 15, 2007 | 10:08 AM
Conanski's Avatar
Conanski
Originally Posted by MintFord
I have too many projects going now, so I'm on a tight budget,.
Nuf said right there....
TBI on a ford? Could this be the fabled CFI system that was made for like 1 year that nobody could fix when it broke? If so, I feel your pain.
Old Oct 15, 2007 | 07:05 PM
MintFord's Avatar
MintFord
haha. it sure is the Crappy Fuel Injection system. Damn thing died on my way home from buying the car. Was able to pull a code for TPS out of range with a jumper and test light. (this car doesnt have a check engine light) I checked the TPS with a meter and it turned out that the TPS would work fine cold but get a large dead spot after it heated up from 10-15 minutes of driving. After replacing the TPS, it runs ok now after the motor warms up.
Old Oct 15, 2007 | 07:08 PM
51dueller's Avatar
51dueller
Technically the CFI was around from 82-85. A 2 barrel carb replaces it nicely...
Old Oct 15, 2007 | 10:51 PM
Conanski's Avatar
Conanski
That's just what I was gonna suggest..
Old Oct 16, 2007 | 11:15 AM
loudfords's Avatar
loudfords
Is that the same junk as Variable Venturi? 2 barrell replaces it too...
Old Oct 16, 2007 | 06:26 PM
MintFord's Avatar
MintFord
I've got a 4Bbl mustang intake. Im just sticking that TBI on my 2bbl intake until I decide between changing the sending unit and running a 4bbl or going with MAF mustang intake/wiring harness. Which would you guys go with? I'm guessing the 4bbl would be the cheaper route.
Old Oct 17, 2007 | 01:21 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
So other than the washers would a set of D0OE 351W heads be a direct bolt-on to a later model (mid-80's) 302 as well? I swear I remember seeing something about a special head gasket because the water passages are different...
Old Oct 17, 2007 | 01:41 PM
mustangman's Avatar
mustangman
go with an edelbrock carb 600cfm,rig it up with a 4 pin gm module straight to a dura spark 1985 steel geardistributor from an 85 mustang if the engine has roller lifters,if not just use any cast iron gear duraspark dizzy,,,,,F### all that fuel injection speggetti wiring,,,,go with a carb very simple
Old Oct 17, 2007 | 04:05 PM
baddad457's Avatar
baddad457
Why would you rig an Edelbrock carb up to a 4 pin GM module ?
