CCV Mod question
Old Oct 13, 2007 | 01:56 PM
CRF1966's Avatar
CRF1966
CCV Mod question
Can I use a piece of 4" PVC instead of exhaust pipe. Reason I'm asking is I have everything to do this mod in my garage but no exhaust pipe just 4" pvc pipe. Wife is gone for the day and I want to do this mod now.
Old Oct 13, 2007 | 02:10 PM
250turbo's Avatar
250turbo
on ccv mod i used 3/4 heater hose
Old Oct 13, 2007 | 02:13 PM
CRF1966's Avatar
CRF1966
I have the 3/4 hose. I want to use the pvc for the delete of where the ccv hose goes into the intake.
Old Oct 13, 2007 | 02:19 PM
250turbo's Avatar
250turbo
i used jb weld on stock inlet
Old Oct 13, 2007 | 02:30 PM
CRF1966's Avatar
CRF1966
So you left the bracket in the intake
Old Oct 13, 2007 | 05:52 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I would think that using a piece of 4" PVC would be ok. I saw someone else here last week that used it. As long as you get a good, air tight seal when you clamp the intake tubes on you should be ok.
Old Oct 13, 2007 | 06:24 PM
gunnertom's Avatar
gunnertom
I didn't want to chime in ,,but I think the size of the pvc is 3 inch, but I could be wrong.
Old Oct 13, 2007 | 06:38 PM
Texas Outlaw
Not a liberal...
The intake tube IDs are 4". They neck down to 3" at the turbo inlet.
Old Oct 13, 2007 | 06:46 PM
gunnertom's Avatar
gunnertom
yea I thought I seen in a post were if you use steel pipe it's 4 " but if you use pvc iits 3 " the diff is the wall thickness
Old Oct 13, 2007 | 08:18 PM
Texas Outlaw
Not a liberal...
Oh I see what you mean now. Sorry about that.
Old Oct 13, 2007 | 08:21 PM
CRF1966's Avatar
CRF1966
Well it's done and just in time closing the hood and the wife pulled up. Little close on that one. Thanks for the input. What mod to do next, I think it will be the aih delete and boost gage. little but little and some day I'll have the dp tuner.
Old Oct 13, 2007 | 08:24 PM
gunnertom's Avatar
gunnertom
Glad you got it done,,,theres more to come.
Old Oct 13, 2007 | 09:54 PM
Izzy351's Avatar
Izzy351
For the PVC, it's a 3" coupler - that's what I used. It's 4" OD. You can't use 4" PVC pipe because it's 4" ID.
Joe
Old Oct 14, 2007 | 08:54 AM
redfire42's Avatar
redfire42
Thought it was 4" OD and 3 1/2" ID for the PVC. I was going to use it also but wanted bigger for more air flow.
