Hello, I am looking to buy a 1971 600 dump truck 2 ton with 2 speed rear end. But the guy doesn't know what size motor is in it. Truck looks good and runs good. Thanks for any help ypu can give me.
Here is the VIN: F61DVK80401
This is stamped on the intake C7TE 9426-K
Firing order that is stamped on the intake 15426378
This is the stamped on the rearend housing 115456
Hello.. New to the site,, I have recently purchased from what the title says is a 1979 F-700.. The truck has a cab from a mid 80'700.. From what i have actually found from a little research is it might be a f-500...Looking for help decoding the vin from title..I do not have the actual dash tag #.. The truck is a retired HD wrecker with twin booms... It is also a 4x4. with a IH front axel with lock outs. Truck is powered by a 390 4spd 2 spd transfer case... Frankenstein... Looking to see what the thing began its life as.. and to see what it was powered with..
Thanks
Luke
Vin-F50CCG74710
Hello.. New to the site,, I have recently purchased from what the title says is a 1979 F700.
The truck has a cab from a mid '80's 700.. From what i have actually found from a little research is it might be a F500.
Looking for help decoding the vin from title. I do not have the actual dash tag # None on trucks of this vintage.
Hello, I am looking to buy a 1971 F600 dump truck 2 ton with 2 speed rear end. But the guy doesn't know what size motor is in it. Truck looks good and runs good.
Warranty Number: F26YCF74000 / W.B. 149 / COLOR code: blank* / MODEL: F260 / BODY: 4 81 / TRANS: A / AXLE: 24K / MAX GVW LBS: 06800 / CERT NET HP: 175 / RPM: 4000 / DSO: 160637
F26 = F250 4WD
Y = 360 2V
C = Oakville Ontario Canada Truck Assembly Plant.
F74000 = 1969.
149" Wheelbase (Crew Cab).
COLOR: Blank*
F260 = F250 4WD, 6,800 lbs. GVWR
4 81: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
24K: 24 = Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity // K = Dana 44 Front Driving Axle / 4.09-1 / No Limited Slip / 3,000 lbs. Front Axle Capacity.
6,800 lbs. Gross Vehicle Weight Rating.
175 net HP @ 4,000 RPM
160637:
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
0637: Domestic Special Order number, the truck was special ordered by the original purchaser, not " bought off the lot."
* When there is no COLOR code stamped on the Warranty Plate, the truck is painted a non standard color per the original purchasers order, making it a Domestic Special Order.
AFAIK, all 1967/79 Crew Cabs were assembled at the Oakville Ontario Canada Truck Assembly Plant. Today, the Edge and 'rebadged' Lincoln version are assembled there.
1-3 Series F10 F100 2WD pickup
4 Engine Y V8 360-2v 215hp 8.4:1cr
5 Plant E Mahwah NJ
6-8 Mod Yr/Mfg Date F51 1969 (Mfg Aug 1969)
6-11 Sequential Serial # F51517 F51517
1948 ford f1
only number found in my frame = 21C50863
1948/50 "RATING PLATE" info is not in my 1948/56 Ford fische. Sorry. You'll have to wait for ND to chime in. Or go to the correct board. This would be better. We here are 67/72 trucks.
