VIN Decoder for older Ford Trucks
#61
Standard Cabs did not come with body side mouldings, but they may have been an option, or an owner or body shop could have bought them at the parts counter, then installed them.
Anodized aluminum grille, headlamp doors, Styleside tail lamp bezels were not available for Standard Cabs.
Ask this fellow: FTE member tripleframe has all the original factory FoMoCo literature used by new truck sales peeps and fleet managers for 1961/66 trucks, because his dad was a fleet manager.
Your '66 has "outie" wheels and painted "outie" hubcaps. Tripleframe and I have had a few "go-arounds" because he says these were not available for 1965 F100's, but the parts catalog says they were.
Outie: So called because the hubcap snaps over tabs located on the outside of the wheels center section.
Innie: So called because the hubcap snaps over tabs located on the inside of the wheels center section.
All 1961/64 F100's have innie wheels/hubcaps. Parts catalog says 1965/66 F100's could have innies or outies, but tripleframe disagrees on '65 F100.
#62
Strange, SMS Upholstery states these were the 2 combined colors but their names and descriptions to do appear to match that of SMS?
tvliftcabinet: Pic doesn't appear when post is quoted, so I had to type the info. The angle of the pic makes the Warranty Plate hard to read.
WB: 129 / COLOR: 8 / MODEL: F100 / BODY: 481 / TRANS: F / AXLE: 09 / MAX GVW LBS: 05000 / CERT NET HP: 129 / RPM: 4000 / DSO: 74
129" Wheelbase.
8 = Springtime Yellow.
F100 2WD .. 5,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
F = Borg-Warner T-18 4 Speed Manual Transmission.
09 = Ford 9" Rear Axle / 3.70-1 / 3,300 lbs. Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Please do not type any additional threads for your '66 F100 in this 1967/72 forum.
129" Wheelbase.
#66
#67
#68
#70
Originally Posted by 351Cleveland C4
Blue Oval Truck Parts has a decoding sheet for every generation, that seems to be very accurate.
I have a Canadian made 48 Ford F-47. ID plate screwed to firewall says,
ENGINE-8E-3837 MODEL-BD83 / TRIM-M-18005-C PAINT-M-14232 / SERIAL-BD83H48-27416
None of this seems to match the LMC truck catalogue description, so any info appreciated.
It doesn't match, because you're attempting to decode the above using a US truck VIN decoder.
You posted this question in the wrong forum, this is the 1967/72 F100 and larger truck forum.
You want the 1948/56 F100 and larger truck forum. There are several members who can decode all this Canadian only info.
1946/68 Ford & Mercury trucks assembled in Canada were only sold new in Canada.
The VIN's and the codes stamped on Rating/Warranty Plates used thru 1965 are unique to Canada, they're not the same as US trucks.
#72
on
Originally Posted by Bigtiny88
Need help figuring out what year this is! Vin is F25HRC61262 thank you in advance
#74
#75
Has the production date printed on the upper left corner, the VIN and misc GVWR's and tire sizes printed on it.
But this truck is a 1968, so it doesn't have this label.
