Sponsored by: Auxito
Only Eight Miles
Old Nov 15, 2008 | 07:38 AM
Aftrmidnite's Avatar
Aftrmidnite
Only Eight Miles
I got a new job and it's just under eight miles from my house. the truck is garage kept, in a semi-warm garage. What I'm wondering, with the weather getting colder, will I have problems because everything doesn't heat up, especially the exhaust and differential. I asked the dealer about a block heater, and they don't install or recommend them. Putting heat tape on the differential would be easy as we always have left over bits of heat tape at work. The vans at work rear bearings and seals take a beating, because they never warm up and aren't driven over 25 MPH. They are lucky to get 10K out of them.
Old Nov 15, 2008 | 09:28 AM
galaxie641's Avatar
galaxie641
It'll be fine.
Old Nov 15, 2008 | 12:19 PM
96f150's Avatar
96f150
It''l be fine....I've never heard of bearings and seals taken a beating from NOT being used
Old Nov 15, 2008 | 01:08 PM
oddballish's Avatar
oddballish
The only seals I’ve had leak due to lack of use were on a 71 F250 on the automatic ,but it had sat for seven years .I’ll go with not an issue in your case
sd1972
Nebraska Chapter
Jan 13, 2014 11:23 PM
Baatzy
39
Jan 8, 2014 09:47 PM
Jbru167
Mar 15, 2009 11:26 AM
Lumberbrok
Nov 9, 2007 06:17 PM
