390 Valve problem?
Old Jun 27, 2001 | 08:31 PM
Blenderhead's Avatar
Blenderhead
390 Valve problem?
Got a 69 390GT. Rebuilt the engine. got a valve job. The problem is that the valves won't seat. When the runners are bolted down the valves don't seat, but if the runners are unbolted a little they seat. Same pushrods and rocker ratio. The cam is the same cam but reground a little. can anyone help? please. Engines been decomishened for 2 months now.
Old Jun 28, 2001 | 02:51 AM
FE427TP's Avatar
FE427TP
390 Valve problem?
ok, by wont seat, do you mean none of the valves are closing? cause in this case you probably needed shorter pushrods when the engine was rebuilt, it sounds like they milled the heads and deck and didn't think about this lowering the pushrod length. If it's just some of them going down this is normal since some valves will be open with the engine just sitting there. another reason why it's good to run a engine every now and then.
Old Jun 29, 2001 | 10:16 AM
bigeric's Avatar
bigeric
390 Valve problem?
The problem with the lifters is easily checked. Put the engine at top dead center, then take off the left valve cover. Both lifters at the forward cylinder should spin freely but not so free that they move up and down a whole bunch. Generally, all lifters on closed valves should spin freely. Most parts stores still carry the lifters in long, standard, and short lengths.
Old Jun 29, 2001 | 11:12 AM
Blenderhead
390 Valve problem?
Talked to a few people all said the same thing about the shorter pushrods. So going to get .060 shorter pushrods and see if that works.
Old Jun 29, 2001 | 09:51 PM
DrFord's Avatar
DrFord
390 Valve problem?
bjmayberry2
Apr 20, 2016 10:53 AM
Snowymountainman
Mar 4, 2016 11:32 AM
gungho351
Oct 30, 2013 04:22 PM
nothercrash
Aug 28, 2011 12:53 AM
HEFTY F350
May 30, 2002 01:00 AM
