Wiring Harness
Old Oct 10, 2007 | 08:25 PM
77F250Custom4spd's Avatar
77F250Custom4spd
Wiring Harness
Does anyone know where i can get a wiring harness or harnesses, dont know if theres more then one you can get
Old Oct 10, 2007 | 09:11 PM
Mil1ion's Avatar
Mil1ion
www.centechwire.com
Old Oct 10, 2007 | 09:45 PM
77F250Custom4spd
I was kinda hoping for one that was specifically for my truck as im not electrically inclined and having one that i know would fit would make it easy.
Centechs all seem to be custom
Old Oct 10, 2007 | 09:50 PM
Mil1ion's Avatar
Mil1ion
Well then it's off to a wrecking yard and hopefully you don't find a butchered one.
Make sure it is the correct one as they changed over the years to allow for newer and revised things.
Cluster wiring !
Gauges are 18 pin connector
warning lights are 14 pin connector
Old Oct 10, 2007 | 10:57 PM
masterbeavis's Avatar
masterbeavis
Anything specific for your truck is going to cost big $$$. What is wrong with the harness you have now?
Old Oct 10, 2007 | 11:16 PM
bucks77ford's Avatar
bucks77ford
Centech is supposed to make the harness work with ford factory connectors and the wiring is color coded and marked so it should be easy to install. Plus you will have a new harness rather than a 30 year old one.
Old Oct 11, 2007 | 09:31 AM
77F250Custom4spd
Mice got to it. And its a tangled mess held together with zip ties and tape
Old Oct 11, 2007 | 09:36 AM
jimherm81's Avatar
jimherm81
check out LMC truck parts
Old Oct 11, 2007 | 02:42 PM
crewcabwannabe's Avatar
crewcabwannabe
I just installed the Centech harness in my '79 250 CC last weekend.. I'm not too much an electrical guy either, and I did ok.. I got tripped up with the alternator wiring, and after just 2 calls to Centech for help (they were VERY patient and helpful!!) we learned it was my alternator with the problem, not the new harness/install. When I bought it, Centech told me "it won't fall onto the truck by itself, but it's not too tough..." They were right- it was a little frustrating at times, but now that it's in, I'm happy with my new harness that no longer has tin foil as a fuse! Take the rat's nest out, pay a friend in beer to help out, and take next weekend and install peace of mind :-)
Good luck!
Old Oct 11, 2007 | 04:12 PM
DutchmanAZ's Avatar
DutchmanAZ
Good luck!
I hope I'm not hijacking here, but I'm looking to do the same thing.
According to Centech, they don't make a complete harness to do the entire truck - just the dash and part of the engine compartment (i.e. no marker lights, tail lights, etc). Didn't sound right to me (I emailed Centech and got the response). Is this correct from your experience? Did the wiring come terminated to a connector to fit your heater fan switch?
Did it include the ignition wiring (not the ignition switch, but rather the ignition wiring in the engine bay)?
Old Oct 11, 2007 | 05:56 PM
Mil1ion's Avatar
Mil1ion
4. Vendor Promoting . Recommendations of vendors by users is encouraged, but excessive promotion of vendors (cheer leading) will be viewed as advertising. Please make sure your participation on FTE is more than just promoting or advertising for a vendor or product.
Old Oct 11, 2007 | 06:32 PM
crewcabwannabe
Dutchmanaz and anyone else on the fence with your harness..
The Centech 'harness' is really several smaller 'harnesses' that when combined will replace most of your truck's current wiring.. On my truck I had to reuse my heater switch, fuel tank selector switch, wiper switch, taillight and marker light sockets, and I chose to reuse my interior light(s) harness (very minor detail).. The kit comes in 9 different bags, and you just pick one bag to install, do as much as you can, and then get the next bag and so on.. about 1/3 of the way through I began to think of it as a giant puzzle, and I just had to 'install' the pieces. A word of warning, it took a full 2 and a half days to wire the truck. If you do it, you will be VERY happy (when you're done!) My rat's nest/butchered stock harness was a fire hazzard, and my truck had the common "slow to crank" problem.. ALL electrical gremlins are now gone-- maybe I'll put power door locks in next- at least this harness can handle the 'add on' stuff. It's a big investment in $$ and work, but I figure one day I'll get at least part of the $$ back at resale.. at least I tell myself that..
Old Oct 11, 2007 | 09:07 PM
DutchmanAZ's Avatar
DutchmanAZ
Thanks Crew -
A couple more questions...did the wires to the heater fan switch terminate into a plug that then fit into the back of the heater switch?
Did removing the dashpad give you enough room to work in the dash, or did you have to remove the entire dash assembly?
Thanks again!
Old Oct 11, 2007 | 10:00 PM
bucks77ford
It would be a nightmare to wire without remove the dash, but that's me and I have mine already removed.
Old Oct 11, 2007 | 10:36 PM
Mil1ion's Avatar
Mil1ion
Originally Posted by DutchmanAZ
Thanks Crew -
Thanks again!
With or without AC ?
