highest hp OBS??
Old Oct 11, 2007 | 02:54 PM
FFemt5287's Avatar
FFemt5287
wow, 750 is quite the large number. will b-codes provide that? or is there something bigger and more insane? also, what kind of turbo requirements are there??
Old Oct 11, 2007 | 03:51 PM
lukecline's Avatar
lukecline
yes he was running b codes, a Hypermax modified h2e and TS Performance 2 stage nitrous IIRC
Old Oct 11, 2007 | 04:04 PM
FFemt5287's Avatar
FFemt5287
how big can they make those b-codes?? (cc-wise) any diy kit to make a-codes into b-codes? whats the difference in the two?
Old Oct 11, 2007 | 05:41 PM
glasseater's Avatar
glasseater
i PMed dockboy on another site AWHILE ago about what he has done and what numbers he was putting out in his 7.3... here's the reply:
"the 7.3 had:
billit rods
lower comp. pistons
fire rings
hmax rev kit
bd 530 injectors
bts oil system
itp fuel system
magnafuel fuel pump
modified h2e
water injection
nitrous
dp tuner programs
bts tranny
and a lot of tweaking.
did a best of 595 rwhp on #2 and 790 on nitrous."
pretty impressive...
Old Oct 11, 2007 | 06:43 PM
powerstroked162's Avatar
powerstroked162
Im pretty sure that you can get B-codes built to whatever CC's you want. Dont quote me but I believe Diesel Jim has a set that are said to be around 400cc's if I remember correctly.
Cowboy Steve
Old Oct 11, 2007 | 08:13 PM
lukecline's Avatar
lukecline
there is a limit to how big they can be made. Ive heard someone was running 500+cc in thier pulling truck.
Old Oct 11, 2007 | 08:24 PM
glasseater's Avatar
glasseater
and the limit is.... the biggest the nozzle can get without screwing up the spray pattern?
Old Oct 11, 2007 | 08:57 PM
lukecline's Avatar
lukecline
biggest ive ran or heard of people running is .012"x 7 hole. Im sure someone has ran larger though.
Old Oct 12, 2007 | 03:43 PM
glasseater's Avatar
glasseater
well the cummins guys run like .028 i think i saw... just look on comp d in the cummins section... but they also only have 6 cylinders and each one is bigger than ours so i guess their injectors have to be larger too...
Old Oct 12, 2007 | 11:27 PM
lukecline's Avatar
lukecline
.028 is huge. I dont think that would be streetable at all.
Old Oct 13, 2007 | 09:26 AM
glasseater's Avatar
glasseater
oh i'm not talking about streetable i'm talking about the sledpullers... we all know they make the most power
Old Oct 13, 2007 | 10:14 AM
ShayB's Avatar
ShayB
Don't forget about Cale Thompson from BTS. He has an OBS that can run right with Zane. They just don't travel around very much. I'm not sure what his latest dyno #s are.
As far as OBS, Zane, Cale and Sapps have got to be about the top. Lott, BigR (Mike), Dockboy, Imelmo (Danny)...they all run superdutys.
We had our '97 PSD to 500 hp on #2 before it went into a lake. Now it has a Cummins going in.
I agree, those sledpullers run some power. Frank from PA has a PSD that is a runner. I bet he is right up there hp wise with Zane, Cale and Sapps as well, and this is his "little" truck.
Old Oct 15, 2007 | 07:02 PM
  #28
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Don't Know how many of you were in Houston this weekend.....but Zane turned a 10.90, then backed it up next pass with a 10.86. Don't know for sure, but I think that makes him the fastest PSD in the land.
Old Oct 15, 2007 | 07:09 PM
  #29
tjbeggs's Avatar
tjbeggs
Yes from what I understand Zane is the first PSD into the 10's. that included the 6.0 and 6.4's. Shay thanks for setting me straight on the OBS vs SD. I call them all the same. There is nothing a SD can do that and OBS can't so I lump them all together when it come to performance. Both need bigger turbo's, fuel systems, injectors, stronger trannies..... to make big power.
Old Oct 16, 2007 | 02:21 PM
  #30
Vengeance's Avatar
Vengeance
Quickest, not the fastest. Lott is still the fastest.
