What could this be?
Old Nov 26, 2007 | 08:40 AM
mikecox1's Avatar
mikecox1
What could this be?
My 2000 5.4 EB seems to have a loud rattling noise that is coming from the area of the passenger side engine fuel rail (it's absolutely not valve train noise). I would characterize it as a very fast rattle, or a slow vibration. I almost think it is a fuel injector but don't really see why a fuel injector would make a noise like that.
Anyone have any ideas what this could be?
Old Nov 27, 2007 | 02:05 PM
DMB's Avatar
DMB
Any chance you changed the PCV valve recently? Non-Motorcraft PCV valves are known to buzz/resonate, and that's about the location you describe as the source of the noise. Put your finger on the PCV valve while the engine is running. If it's the valve, you'll feel it and also stop it from resonating while touching it. Found this out recently when I installed a Fram. Replaced with a Motorcraft and problem disappeared.
Old Nov 27, 2007 | 03:45 PM
gistecknician's Avatar
gistecknician
Definately sounds like the PCV valve, but if by some chance that is not it check the mounting bolts (8mm??) for the fuel rail.....especially if you recently had the spark plugs changed as some people remove the fuel rail to get at the rear plugs.
