Help identifying 4v FE intake
Old Aug 3, 2001 | 12:37 PM
ksd's Avatar
ksd
I'm looking at a 4 bbl cast iron intake manifold that I'm told was taken off a 390 out of a 65 car. The part number cast into the top is C5AE-9425-C. Can anyone tell me about it? Would it be a good match for my 69 360 FE (currently with 2 bbl intake)?
ksd
69 F100 Explorer lwb 2wd FE 360 C6 3.25:1. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
Old Aug 3, 2001 | 01:20 PM
BB's Avatar
BB
See https://www.ford-trucks.com/dcforum/DCForumID7/57.html
This manifold has the tall ports and I am assuming your ’69 360 heads have the shorter ports. There would be a mismatch with the head acting as a dam on the bottom of the manifold runner. Not a good thing but Ford recommended the CJ manifolds on the GT’s even though they have the same mismatch problem.
I think you would be much better off with any of the “S” intakes with your heads imo.
Barry
Old Aug 3, 2001 | 02:51 PM
ksd's Avatar
ksd
Thanks. That's exactly what I was looking for. Frankly, I don't know what size ports I have, as I've never had my existing manifold or heads off, and I don't know for sure whether they are original.
ksd
Old Aug 3, 2001 | 05:48 PM
6t6merc's Avatar
6t6merc
Hey Barry, I have one with #C8OE-9425-C that appears to be cast with a spread-bore carb in mind but is machined for Holley. Do you know what's up with that?
Eric
Old Aug 3, 2001 | 06:26 PM
BB's Avatar
BB
https://www.ford-trucks.com/dcforum/User_files/BBB/3b6b2f857f4064bd.jpg
They are all like that. Don’t know the story but it is one of a few small differences between the CJ and the so-called identical PI unit. Maybe they planned on a spreadbore version like the 429CJ?
Barry
Old Aug 4, 2001 | 10:33 AM
DrFord's Avatar
DrFord
I have an intake that I bet you haven't seen many of. It is a 4v FE ,identical to the picture of barry's, with one exeption, mine has a freeze plug in it. yep it is right under the heater hose neck. I am not sure but I think the casting is of a 63'
Old Aug 5, 2001 | 11:34 AM
bsprowl's Avatar
bsprowl
That "freeze plug" opening was used for an oil filer/breather tube before emission rule dictated PCV valves etc.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 6, 2001 | 03:17 AM
karljay's Avatar
karljay
tstewart78
Feb 22, 2016 03:13 AM
7283-F250
May 9, 2014 08:26 PM
110
Nov 1, 2013 08:06 AM
75boogieman
Apr 11, 2013 05:10 PM
69SWB
Oct 15, 2002 07:22 PM
