which new superduty?
the question - how smooth and quiet is the v10? i can not find one to test. i have driven several 5.4 f150's and the engine sounds like bolts are loose in the crankshaft under acceleration. i am moving up from a toyota 4.7 double overhead cam v8 that is smooth as silk. i have had 2 tundras with a total of zero drivetrain issues over 8 yrs. as a daily driver used by someone who has a heavy foot how does the v10 compare? is it like the ford 5.4? i read the dz mag comparison and the v10 and 6.4 are pretty darn close to 60 and 70 but how does the v10 sound/feel during acceleration/passing. does it sound like it is working really hard when you tow a heavy load? also how loud is it on the highway at 74mph? i am sure it would be more than enough for my towing needs, but i feel there is more to an engine/trany than the numbers 0-60 etc. the cold starting and reliability are the attractive parts to me in northern wi. don't have time to sit at the dealer as i work a lot. i put 10,000 miles per yr on the truck so milage between the v10 and psd is not a big issue. i thought the 6.4 was pretty darn quiet and did not sound rough under a heavy foot.
thx
ts
The V10 has gobs of torque which is something your Toyota did not have. Get the 4:30s and you will have plenty of power to pull your trailer.
There is really no reason to spend the extra $$$ on the PSD unless you spend a lot of time towing heavy above 5,000 ft.
You can't beat a gasser for short trips. My V10 is completly warmed up during the winter in 2 miles of driving.
I would go on Ford's website and do a search of dealer inventory to try and find a V10 in your area to take out for a test drive. I guarentee once you drive one the PSD will be in your mind no more.
It has basically come down to personal choice. Which I think is extremely valid reason. It is your money so spend it how you want.
Longevity -> v10 proven 6.4 new with new technology(so far looks like a winner though)
Millage -> close; some 6.4 still post 17 or 18 MPG but MOST people that post get around 15. With the cost of fuel 3 mpg looks great on paper but is really a wash when you look at the cost for fuel per mile.
Towing -> Unless you tow heavy or in the mountains allot either will get the job done. Ford does towing right! The torqshift tranny and factory break controller rock!
Performance mods -> easier with a PSD BUT be ready to cover all engine work out of pocket
One final not I am not sure about the new diesels but I do love on a cold morning I let her her run for 5 minutes and having heat, not having to plug it in at night or worrying about the fuel gelling.
I have about 45K on my truck. I drive her hard unloaded she sees 80 MPH on the highway and she gets her share of WOT and quick starts. No, I do not beat her. At 45K it still is like new. I have had a few minor issues that had NOTHING to do with the power-train. It has been at the shop 1 time overnight and that's because they took the dash apart and did not have a replacement bulb.
Decisions decisions.
I have yet to read anything that would NOT make me buy another V10. The V10 just suits my occasional towing better than the diesel.
And since I live in the extreme cold the gasser is hands down easier to live with.
Been there, got the t-shirt with cold weather+diesel.
I live in Minnesota, and I only plug in the block heater when the temp will drop below zero. In fact, I only do that to minimize wear and tear on the engine during start-up, not because its necessary. I've started the truck at twenty below and colder on many occasions and about the only difference from a summer start is that the engine revs higher when it starts cold. It throws out heat in these conditions within just a few miles, maybe 4 or 5.
Here's an experience of mine as to how much noise the V10 makes. The manual transmission has 6 forward gears: Low, 1 - 4, and OD. On one early occasion when I was specifically doing what I could to get good gas mileage, I wound up unintentionally driving 25 miles in 4th gear at 75 mph because it was so smooth and quiet. I didn't even know I wasn't in OD until I went to downshift to exit the interstate....
By the way, the V10 and the 4.10 axle makes 70 at about 2100 rpm with the 6-spd, and the interior cabin noise is about like that of a car. It also has a really broad power band - 3rd gear legitimately covers 15 to 85 mph. In fact, depending upon the load and terrain, you can readily use 3rd, 4th or OD to run at 85 mph.
Oh by the way, you asked about "heavy footing" it..... Well, you must be talking about 2nd gear and above, because nobody in their right mind floors a V10 in the bottom two gears.... You do know these load range E tires cost over $100 each don't you? That's okay, if you don't, your wife can remind you....
It does occur to me that there is one misconception I should clear up. People say the gas engines don't smell as bad as the diesels, but I'm not so sure. After all, burning rubber is burning rubber.....
There is another point you might want to consider depending upon your real-world practical objectives. The pre-2005 V10's get a couple a mpg better than the newer ones, mostly because they are quite a bit lighter, and have less horsepower and smaller brakes. You'll also want to pay attention to the pre-2005 "popcorn plug" issue, which I won't go in to.
I really would like to encourage you to find and drive a V10 before deciding. Many of the people in these forums are ex diesel-heads who appreciate the reliability and maintainability of this engine as a work horse, not a race horse. Good luck with your decision.
boy, the more i read, the more the v10 sounds like it is the way to go.
Best, CB
Best, CB
how did you decide between the 250 and 350. what is the downside to the 350 besides a little cost? i drove one. is the ride really and different between the two?
thx
The mjority of us here, are in the V10 because we finally found a truck with a quiet, reliable, effecient motor that costs much less to buy, maintain, and operate then the PSD we traded away from. The are one or two that went back to diesel and a few that went from v10 to PSD and back to v10
With the exception of long haul very heavy at high altitude---- there is nothing the PSD trucks can do that the 3v V10 with ZF 6 or 5R110w TorqShift and 4.10 to 4.30 can't do.....
Now if you want to save some money on the purchase of your new truck, purchase some shares of Ford stock. Then call investor relations, tell them you are a share holder and would like an X-Plan to make a new vehicle purchase. You will be able to purchase behind invoice plus recieve any and all rebates. Some times there are rebates not offered to the public, only to Ford X, D, A plan purchased. Currently Ford stock is under $9 per share. Who knows you may not only save some money on the purchase of the new vehicle but make a little money in the market also.
