Hi guys, i am currently driving a F150 2002 with a 4.6lt romeo eng, does anyone has a chart with values in ohms versus temp. of a cht sensor, reason for this, i have a temp. gage fluctuation with no apparent reason, gage runs fine in the close middle range, the next second it's up to 3/4 and back down to lower middle range where it usually stands, if i shut the engine off and restart, it will go back to it's normal position, engine runs fine with no sign of o'heating, no codes, probably a bad sensor, but first i would like to check sensor for resistance against temperature on the engine, changed thermostat recently with oem one and flushed prestone completly, still had the same problem, please advise,
