Service engine soon light
Old Oct 9, 2007 | 04:52 PM
jhand124's Avatar
jhand124
I have a eary 99 350 with the 7.3. It has the edge module with attitude stacked with the predetor programer, neither is set to max. Truck also has afe intake and 4" exhaust. My service engine soon light comes on under heavy throttle and when towing. When towing the edge will defuel at medium boost, it's set to defuel at 26 psi and the egt's are with in limits. The turbo will also experience compressor stalling at 18-22 psi.
I heared the the light was due to the map sensor receiving a incorrect info. Has anybody experienced these symptoms? What did you do to correct them?
Old Oct 9, 2007 | 05:15 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Your truck will start defueling at 22-23 boost. And will throw the light.
Edit: Welcome to FTE.
Old Oct 9, 2007 | 05:19 PM
miller_feed
http://www.itpdiesel.com/store.php?c...on=show_detail
Get one of these. Most have them with chips.
Old Oct 9, 2007 | 05:30 PM
jhand124's Avatar
jhand124
Thanks, I just ordered it. What is the max boost you get out of your 7.3 and do you have compressor wheel stall.
Old Oct 9, 2007 | 05:33 PM
jhand124's Avatar
jhand124
What is FTE?
Jason
Old Oct 9, 2007 | 05:39 PM
zx250's Avatar
zx250
Of the next Riffraff East
FTE = The greatest site on earth or, Ford Trucks Enthusiasts. The same thing. Welcome to the site.
Old Oct 10, 2007 | 07:56 AM
miller_feed
I can get 30+, but I don't like to go that high. Best to keep it no more than 25#. I would be careful with that programer. My DP-TUNER helps control my tranny. Shifts great and keeps it cooler. You can do lots of harm to your tranny if your programer/chip does not help with this. At 25# boost, I get no turbo surge.
Old Oct 10, 2007 | 08:38 AM
jhand124's Avatar
jhand124
I have the same tuner, and edge with attitude, afe stage II, 4" exhaust, tranny has beefed up shift kit and torque converter from TSI, it less of a slush box. I think I'm going to have to increase the housing size to get rid of the surge, mine ocurrs at less than 25#.
bigdummyford
17
Oct 22, 2009 02:15 PM
flashart24
Feb 24, 2009 01:18 PM
LaxPlaya21
Sep 22, 2006 10:54 AM
clouden
Mar 30, 2006 11:02 PM
