Ranger problem
Old Oct 8, 2007 | 11:19 PM
Xetchx's Avatar
Xetchx
Exclamation Ranger problem
03 Ford Ranger Edge 3.0L V6 MIssfiring bad
so far we've changed the coil, plugs and wires . but no change
any ideas?
Old Oct 9, 2007 | 05:45 AM
tomw's Avatar
tomw
Fuel filter, dirty injectors, leaking vacuum lines, fuel pressure regulator, bad ignition switch, bad E/DIS ignition module, bad alternator, loose nut behind the wheel.
HOw many ideas do you want? Is that enough?
Seriously, think fuel, air, spark. That's all it takes. Too much or too little will cause a misfire. CHeck to see if you have enough or too little of the fuel & air. You've done the heat (spark) thing.
tom
Old Oct 9, 2007 | 07:04 PM
blue beast's Avatar
blue beast
Gas line dryer first, 2 bottles of heet 2 bottles of iso heet on whatever is in the tank 3/4, 1/2, 1/4 tank run it until 1/8 tank and refill with fresh gas and 2 more bottles of iso heet.. Get some Crc MAss air sensor cleaner take the sensor off the intake tube and spray it for a few seconds let it dry, then do it again until those wires in there are clean. At night get a spray bottle filled with water and spray the wires from coil pack to spark plugs, start the truck with all lights off, look for sparks jumping between wires, to metal on motor, or to low voltage wires which is pretty bad. You will have to reroute the wires or add stand offs or split loom to prevent the arcing!!
Ranger_Diesel
1983 - 2012 Ranger & B-Series
Feb 17, 2011 05:17 PM
lamppost
New Member Introductions
Oct 25, 2007 06:48 PM
Epd444
Feb 24, 2007 09:03 PM
wjackson316
40
Dec 13, 2005 05:25 PM
joefran
Aug 2, 2004 07:49 PM
