Offroad & 4x4
axle swap
Old Oct 7, 2007 | 06:29 PM
dm_lucky1820's Avatar
dm_lucky1820
axle swap
I have a 87 f150 and I want to swap out the front alxe for a solid axle. So far its got a 4'' lift with 36'' swampers and a beefed up rear end with stronger axles and a locker. and I just wanted any advice as to which axle to swap into the front end.I seen broncograveyard.com has a converstion kit that uses a high pinion dana 44 out of the 70's bronco and f-150s how strong would they be?
Old Oct 7, 2007 | 06:40 PM
surewhynot's Avatar
surewhynot
The easiest to use is a dana 44 out of a 78-79 F150 or Bronco. There are alot of threads here about the swap. Search for SAS and you should find plenty. Heres one thread- https://www.ford-trucks.com/forums/6...?highlight=sas
Here are some pics of the SAS I did on my 94 F150. I have 12 inches of lift and run 40's.
http://s111.photobucket.com/albums/n...ogress%20pics/
Old Oct 7, 2007 | 07:54 PM
blue beast's Avatar
blue beast
The ttb is a dana 44 so if you are going through the trouble might as well go all the way and get the biggest axle you can afford. My vote is for portal axle d60's!!
Old Oct 7, 2007 | 08:10 PM
79-400-POWER's Avatar
79-400-POWER
rockwells?!?!?!
Old Oct 7, 2007 | 08:30 PM
MBBFord's Avatar
MBBFord
A solid axle D44 with chromoly axle shafts can handle some abuse, but not as much as a D60. Thing is... D60s aren't cheap. a easy $1,000.
What are your plans for this truck. A stock D44 can't handle much more than what you have now, and your TTB is pasted it's max with 36s.
Old Oct 7, 2007 | 08:40 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by 79-400-POWER
rockwells?!?!?!
hey!.....thats my line.....hahaha....
Old Oct 7, 2007 | 10:33 PM
godblessmud's Avatar
godblessmud
a dana 60 front w/stock rear would leave you with 8 lugs front and 5 back...inconvientient. im doing same thing, but going with sterling 10 1/4 rear and Dana 60 front... that is soon as i find a D60 front...
Old Oct 8, 2007 | 02:32 PM
79-400-POWER
ha ha ha ha ha. beat you to it
Old Oct 8, 2007 | 07:37 PM
dm_lucky1820
My plans so far with have been a trail runner with mild rocks and mud. Want to upgade to a solid axle to i can hit a few bigger rocks and more extreme trails.
Old Oct 8, 2007 | 09:18 PM
MBBFord's Avatar
MBBFord
For trail riding and rocks, the D44 with chromolys is going to have hell, a D60 would do better, but it's pricey.
Trey430
Mar 29, 2012 09:35 PM
rampus
Mar 14, 2011 01:01 AM
BLK SHP
Jan 17, 2011 06:49 PM
beezerinio
Jul 8, 2002 11:12 PM
