Setting My Timing
Old Oct 7, 2007 | 04:58 PM
Skandocious's Avatar
Skandocious
Setting My Timing
Whelp! I borrowed my buddy's brand new Craftsman Inductive Timing light and started my first timing check. Removed the SPOUT connector, clamped the front passenger wire (#1 I hope), clamped the battery terminals and fired her up. Shot the light at the balancer and found that someone had already marked it for me, assuming the mark was correct I went ahead and set the timing according to that mark. It spun too fast for me to get a shot of the mark but it looked like this when I started:
So I unscrewed the hold down not on the distributor and rotated it counterclockwise a bit and got it looking like this:
Took the truck out for a drive and it has no power!! I got out onto the main drag and gave her some juice, the engine revved up just fine but the truck barely went anywhere. Anybody know what I did wrong?
Old Oct 7, 2007 | 05:03 PM
radialarm's Avatar
radialarm
Is that white paint on a line or just marked there I believe the mark is the groove cut in the damper. Try marking it there and try again.
Old Oct 7, 2007 | 05:11 PM
Skandocious
Yeah I'm not exactly sure where the actual line is because it's hard to tell when the balancer is spinning. The white line that you see was drawn in by me with MS Paint.
The line that's there now was already there when I started my timing... I'm just assuming its in the right place... What are you supposed to use to mark that balancer to make the timing light shine light it up?
Old Oct 7, 2007 | 05:19 PM
radialarm's Avatar
radialarm
Anything light colored chalk, white-out etc. Try another color like yellow or something to tell the difference between the two marks
Old Oct 7, 2007 | 05:26 PM
DJdemon6696's Avatar
DJdemon6696
the timing marks are on th balancer.. chek it good... becuase where you marked it i didnt see the marks... rotate it or get under the truck to see the marks.. you Will see 20 BTDC* 10 BTDC* 0 * and 10 ADTC* mark it where you want it to be and set it at the marked ontop of the balancer
Old Oct 7, 2007 | 05:32 PM
Old_Paint's Avatar
Old_Paint
I was going to point out that I didn't see the normal incremental marks, but you beat me to it. Did we have the pickup on the right plug wire? (#1 plug). I brightened my balancer with scotch-brite so I could see the marks, then put a narrow white mark on the 10* mark.
Old Oct 7, 2007 | 05:35 PM
Skandocious
I'm not sure that you guys are understanding correctly...
That white mark that you see is IN THE WRONG PLACE. I painted that in with Microsoft Paint just so you guys could see where the timing light was showing my timing was at... IT IS JUST A REPRESENTATION because I couldn't catch a picture of the mark with the balancer spinning...
Old Oct 7, 2007 | 05:39 PM
handsomerob's Avatar
handsomerob
My harmonic balancer has actual timing marks on it, you can kind of see them here.
Old Oct 7, 2007 | 05:44 PM
handsomerob
Umm from what I understand, you should then put some paint in the groove, disconnect the spout, losen the Dist. and while watching the harmonic balancer turn the Dist till the new marked groove is lined up and then shut the engine off, tighten the bolt and then check the timing again to make sure it didn't move while tightening. after the timing is set, connect the spout and check it again it should be advanaced with the spout conected.
Skandocious
Thanks Rob, I just found those marks and the existing white mark was at 0*
I'll remark it at 10* and set it again. Thanks for your help guys.
Old Oct 7, 2007 | 06:28 PM
Skandocious
All fixed, thanks guys. Handsomerob, rep points to you for being the first person to ever post a picture of the actual timing marks (first one I've seen at least).
Old Oct 7, 2007 | 06:57 PM
quicklook2's Avatar
quicklook2
for any one else doing this, you find, clean and mark the degree marks first.
saves a lot of headaches.
Old Oct 7, 2007 | 06:58 PM
handsomerob
No Prob, I took it while I was trying to figure out my Timing issue.
Old Oct 7, 2007 | 07:01 PM
Skandocious
Good advice. I started by just throwing the light on the balancer to see what it looked like and found that there was already a mark, and got excited. Set it according to that mark and then later realized that the mark was on 0* TDC.
So the lesson to learn here is that even if there is a mark on the balancer, you can't trust it unless you put it there yourself. Thanks for the help guys.
Old Oct 7, 2007 | 07:20 PM
radialarm's Avatar
radialarm
Sorry! I couldn't stick around my daughters mom came over and wanted to go shopping. I'm glad to see you got it fixed.
