so... is there a wrong way to do this?
I went from gutted cats to high flow cats with everything Tig welded and road tested within 2 hours and the difference was only just detectable. This with a 4.6litre with 5 speed on the same road as before from low rpm's to 6,200 rpm's.
Granted a plugged up cat or one with broken and melted guts will be highly restrictive. OEM want the best flow and HP numbers for their vehicles staying within the smog laws and limits for their stock production motors.
Reminds me of people who hate Holley carbs thinking they can make it better by modifying it better than the engineers.
"what bear river claims, cats DO restrict airflow and affect the powercurve of engines. and dont try to tell me otherwise ive seen the dyno graphs to prove it."
The point is, probably 99% of the time when good factory or aftermarket cats are used, the difference is not enough to notice.
Beemer Nut, just how does a Ford sound at 62,000 RPM?? LOL Just kidding.
This testing was done on the 4.6 litre
LandRover Discovery motor that had minor port
work then intake and exhaust gasket matched.
Added a small cam with chip and Borla's cat back with
CarSound high flow cats.
Now Rover's OEM cats are a sorry restrictive POS,
that seem to work ok with a stock 3.9 motor with auto
trans. With the 5 speed and larger 4.6 that is breathing better
they would choke the motor and make it run hot besides it is
normal for their cats to rattle and fall apart. And ya thought British
had the market cornered on oil leaks and bad electrics.
I used 3 commercial grade 6.5 HP (yea right 6.5 HP on 110 volts what a joke) vacuum cleaners hooked up to a section of 4" PVC with PVC caps on the ends, one end drilled out to 2 1/4" to seal against the cats with a vacuum gauge on the other end cap.
I found that both style Disco cats round or flat flowed about the same, gutted a lot better and the matched set of flat CarSound high flows a little less than the gutted cats but much better than either OEM Disco cats.
As far as "they plug themselves" I haven't noticed a difference in performance
or speed from new over the last 57K miles going up the mountains same roads and grades and weight 3 times a year the last 5 years. Same speeds and gears pulling grades from sea level to 9,600 ft. Yes I have notes on the grades with speed results and gear I pulled floored, got to love 5 speeds.
Just passed smog here in Cali before the new fuel tank pressure leak test begins in November 1.
New cat test HC idle 6, HC 2,500 7 (PPM) max allowed 100 and 180 (PPM)
57,000 mile test HC idle 9, HC 2,500 11 (PPM)
%CO2 idle 14.4%, 2,500 rpm 14.6%
O2 idle and 2,500 rpm 0.3%
CO idle and 2,500 rpm 0.00, max allowed 1.00% and 1.10%
These numbers are a sniff test only as the Disco is a full time 4 x 4
and the state doesn't have 4 wheel drive dynos.
So far so good plus almost the same results with a MagnaFlow (CarSound)
high flow cat on a 87 325is BMW.
Gutting the cats is not likely to lean out the mixture on a FI vehicle, since the computer is just going to adapt. However, it does create an expansion chamber that slows down the exhaust, and also cools it. This so if anything, the gutted cats might perform better than a factory cat, but probably worse than a good high flow cat or straight pipe.
Part of the restriction from a factory cat has to do with the length of the substrate. Most "high flow" aftermarket converters are just 4" long, while OEM cats are often 6" - 12" long depending on year make and model. So between that and the thicker walls you get some performance losses, but its really hard to tell the difference without a dyno.
