Po141 Oxygen sensor ???
Old Oct 7, 2007 | 01:01 PM
broncomutt's Avatar
broncomutt
Question Po141 Oxygen sensor ???
I have a 2003 expedition with 90000 miles and the check engine light came on about 3 months or (2000 miles) ago.
I have put new air filter and cleaned the maf with maf cleaner and it went off for the 3 months and about 2000 miles but now it is back on
auto zone test showed too lean code Po141 and recommended an oxygen sensor
I searched on line and everyone said it probably is not the oxygen sensor
I dont want to spend the money if it is not the o2 sensor
The 50.00 is not an issue I just want the problem fixed. I have been told that o2 sensors rarely go bad on there own they usually are caused to go bad by other problems
The motor runs great no noticible problems
I get about 15 miles per gallon ( I have only owned this for about 8 months so I dont know if this is good or not)
Anyway to make a long question longer
any advice or shoud I just replace the 02 sensor and keep my fingers crossed
Old Oct 7, 2007 | 05:18 PM
TexFinn's Avatar
TexFinn
If your online searching resulted people saying not to replace the O2 sensor, then WHAT was the resolution these people suggested?
If the O2 sensor is only 50 bucks, why not replacing it? Then you have eliminated at least one possible cause for the code. Many times resolving these issues requires eliminating one possible cause after another.
And I would say that at 90K miles it wouldn't hurt to change the sensor out, anyway.
Good luck.
Old Oct 7, 2007 | 05:38 PM
broncomutt's Avatar
broncomutt
They suggested cleaning the maf
and others said look for vacuum leaks
I have done both
I just worrie about replacing the o2 sensor and having it go bad because of other issues. I was also told that they usually dont go bad on their own
most people who had vacuum leaks said theirs ran rough at idle (mine does not)
so I also ruled that out
I am not familiar with what is all involved with these engines and what would cause one to throw that code
but I guess I will just change the 02 and hope it does not happen again
Old Oct 7, 2007 | 06:56 PM
Fordtech1's Avatar
Fordtech1
P0141 - HO2S Sensor Circuit Malfunction (HO2S-12) During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected. Possible causes include Short to VPWR in harness or HO2S. Water in harness connector Open VPWR or GND circuit Corrosion or poor mating terminals and wiring Damaged HO2S heater or a damaged PCM.
Old Oct 7, 2007 | 07:06 PM
broncomutt's Avatar
broncomutt
Ok so I am new and Dont I get 1 free pass for being a noob
I meant code PO171 sorry for any confusion
Old Oct 7, 2007 | 07:13 PM
FTE Herman's Avatar
FTE Herman
Replace (I didn't say check) the vacuum elbow at the PCV.
Old Oct 7, 2007 | 07:18 PM
Fordtech1's Avatar
Fordtech1
OK, 1 free pass...
P0171 - System too Lean (Bank 1)
The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
MAF sensor (contaminated, damaged, malfunctioning, etc.)
Possible causes:
Fuel System
Fuel pressure regulator (leaking, malfunctioning, etc.).
Fuel filter plugged, dirty.
Fuel pump (weak, check valve leaking, etc.).
Leaking/contaminated fuel injectors.
Low fuel pressure or running out of fuel.
EVAP canister purge valve leaking (when canister is "clean").
Fuel supply line restricted.
Fuel rail pressure sensor (incorrect reading).
Air Induction System
Air leaks after the MAF.
Vacuum leaks.
PCV system (leak, valve stuck open, etc.)
Improperly seated engine oil dipstick.
Air induction turbulence due to incorrect air filter.
Exhaust System
Exhaust leaks before or near the HO2Ss (exhaust manifold gasket, mating gaskets, etc.).
EGR System
EGR valve tube/gasket leak
EVR solenoid vacuum leak
Secondary Air Injection
Damaged/malfunctioning secondary air injection system (mechanically stuck valve).
Good Luck!
Old Oct 7, 2007 | 07:19 PM
TexFinn's Avatar
TexFinn
Okay... That changes things a bit.
Clean the MAF and check vacuum leaks. Those should solve the issue. Maybe replace the fuel filter while you're at it. That might also have an effect on setting the code.
broncomutt's Avatar
broncomutt
I must be confused
when did you say replace
Old Oct 7, 2007 | 07:26 PM
Fordtech1's Avatar
Fordtech1
Maybe the elbows at both ends of the PCV tube, eh hkiefus?
Old Oct 7, 2007 | 07:32 PM
broncomutt's Avatar
broncomutt
If there is a vacuum leak will would there be signs of rough idle Thats what I was told so I did not put a lot of time looking for leaks
or would that be just if it was a major leak
I have already cleaned the maf and it came back so I will spend some more time looking for leaks
and I will also change the fuel filter
Thanks for the advice
Old Oct 7, 2007 | 07:36 PM
Fordtech1's Avatar
Fordtech1
A vacuum leak large enough to cause a rough idle would probably be easy to hear, and would most likely set more lean codes.
Old Oct 7, 2007 | 07:59 PM
broncomutt's Avatar
broncomutt
I looked at the pcv valve and it was barely pushed in
I was able to push it in probably 3/8 of an inch the tubes and elbows look great
I did have a hose that comes out right in front of the throttle bodie that is plastic and raps around into the back of the engine and then goes into a rubber hose about 6 inches long then attaches to a silver tube that was very loose and after i pushed it back together it still feels like it is just hanging there
but thats about all I can see
I put it back together and restarted the engine and the check engine light still on but i dont know if i have to clear it first so I removed the bettery cable and will see if that works
Juan0215
Jul 25, 2017 10:19 AM
rogerranger2122
1983 - 2012 Ranger & B-Series
23
Aug 8, 2016 06:24 PM
frosty95
18
May 13, 2016 09:21 AM
wakum6
Nov 30, 2014 06:02 PM
churioz
Mar 8, 2012 03:09 PM
