Sponsored by: Real Truck
Trailer Plug
Old Oct 7, 2007 | 11:49 AM
Spirit615's Avatar
Spirit615
Trailer Plug
I dont know if this is the same for other super duties. When I plug in my trailer to my truck, I have to leave the key in the ignition in the accesory positon to get any power to the trailer. Is there anyway to rewire the plug so the I can get power to the trailer with out doing that? My dads dodge is like that and I find it alot more convenient. Any ideas?
Old Oct 7, 2007 | 01:29 PM
KR DRIVER's Avatar
KR DRIVER
dont know
but my 03 f 350 does same thing
Old Oct 7, 2007 | 07:33 PM
F350-6's Avatar
F350-6
Are you talking about a power wire for running a light or something in the trailer? The tail lamps and flasher should work with the key off. If you're just looking for a power wire you could trace it and run it to your battery through a fusible link.
Old Oct 8, 2007 | 12:15 AM
aldridgec's Avatar
aldridgec
They do it that way so you don'tkill the battery with the trailer. Typically that wire is used to charge the trailer batteries, so it would kill the truck when the engine wasn't running.
Without knowing the year of your truck can't tell you which wire. They changed signifigantly year to year.
Old Oct 8, 2007 | 10:33 AM
Beerstalker's Avatar
Beerstalker
Check your manual for the trailer tow charge relay. Pull the relay and put a piece of wire between the #30 and #87 terminals. This will make the trailer tow battery wire hot all the time. Be advised that this will allow the trailer to drain your truck battery and may kill them prematurely.
Old Oct 8, 2007 | 11:44 AM
Spirit615's Avatar
Spirit615
Thankyou. Do I put the relay back in or leave it out?
Old Oct 8, 2007 | 11:52 AM
rbaker6336's Avatar
rbaker6336
think if I done this would run a switch where I could still turn it off and on
done a similar setup on my older trucks for feeds to winch,lift,etc
Old Oct 8, 2007 | 12:55 PM
redford's Avatar
redford
FTE Leadership Emeritus
Another alternative is to put a small 12V battery in the circuit on your trailer. A gel cell would work well. That way you'd have lights without modifying your truck, plus your truck would chage the battery while you drive.
Old Oct 8, 2007 | 01:15 PM
aldridgec's Avatar
aldridgec
Definitely make sure it is a deep cycle battery if you do add a battery to the trailer!
Beerstalker, great idea. Makes a really easy modification to do that, either way jumpered or switched and jumpered!
