Forgive me for going a little OT here, but I don't know a whole lot about the 6.0. Is it the head studs that are the problem with head gaskets popping, or is it the gaskets themselves?
the stock head bolts are "torque to yield" type, also known as stretch bolts. they are not very strong to begin with. there was also an issue in the past with them coming from the factory without even being torqued down sometimes.
once you replace them with actual studs the motor is exponentially stronger.
I also found it pretty hard to be 100% accurate torquing down the ARP studs... because when its getting past 200ft-lb (I torqued them in 6 stages) they sometimes just want to lock falsely clicked my torque wrench.. I sometimes need to 'convince' them to turn a bit more...
My theory is that maybe I did not spread enough arp grease on bolts/ washers... maybe not.. anyway they can't be really far from one another... 250# or torque is a lot of clamping force is you ask me!
