Here are a few pics of my removed cab.
Old 10-07-2007, 03:01 AM
mulot30th's Avatar
mulot30th
mulot30th is offline
A couple hours after cab lift:
Engine with studs....
Ready to lower cab on it!
Here you can clearly see I have no more EGR
BFH mod done to cab
that's it...
Old 10-07-2007, 08:01 AM
gvandyke's Avatar
gvandyke
gvandyke is offline
Thumbs up
That most deffinetly gives easy accese to the 6.0 PSD.
Greg
Old 10-07-2007, 10:09 AM
raptor131's Avatar
raptor131
raptor131 is offline
thats awesome. Thanks for the pics. How much work is it to remove the cab? in hours
Old 10-07-2007, 11:50 AM
mulot30th's Avatar
mulot30th
took 10 hours to remove (had to figure out how everything was connected).
took 3 hours to bolt it back.
So I guess if I had to do another time, it would take 3 hours at most to unbolt it again
only thing, I had to empty the A/C in the atmosphere... so I will have to get it refilled...
Old 10-07-2007, 11:58 AM
69cj's Avatar
69cj
69cj is online now
Question
What does "bfh" stand for?
Old 10-07-2007, 12:24 PM
6.0superduty's Avatar
6.0superduty
6.0superduty is offline
big f-ing hammer
Old 10-07-2007, 12:32 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is online now
big forking hammer
Old 10-07-2007, 02:12 PM
cable666guy's Avatar
cable666guy
cable666guy is offline
This was to replace the head studs? Unbelievable. The pics were cool, though. I've never seen that side of my turbo before!
Old 10-07-2007, 02:30 PM
gb'sfx4's Avatar
gb'sfx4
gb'sfx4 is offline
old enough to know better
unfortunatly , i have seen my own truck
with it's cab up in the air too many times.
Old 10-07-2007, 05:26 PM
mulot30th's Avatar
mulot30th
yes to replace head studs since mine lifted head under race mode while towing a 5k.. trailer...
Was still going good up to 400hp tow tune...
so this time went with arp...
Old 10-07-2007, 06:30 PM
MisterCMK's Avatar
MisterCMK
Forgive me for going a little OT here, but I don't know a whole lot about the 6.0. Is it the head studs that are the problem with head gaskets popping, or is it the gaskets themselves?
Old 10-07-2007, 07:06 PM
mulot30th's Avatar
mulot30th
In my case, it was the head lifting under very high torque situation. The gasket was still perfectly sealing under stock, two and tow 400 tunes.
Old 10-07-2007, 08:05 PM
LvTitan's Avatar
LvTitan
LvTitan is offline
the stock head bolts are "torque to yield" type, also known as stretch bolts. they are not very strong to begin with. there was also an issue in the past with them coming from the factory without even being torqued down sometimes.
once you replace them with actual studs the motor is exponentially stronger.
Old 10-07-2007, 09:19 PM
mulot30th's Avatar
mulot30th
I also found it pretty hard to be 100% accurate torquing down the ARP studs... because when its getting past 200ft-lb (I torqued them in 6 stages) they sometimes just want to lock falsely clicked my torque wrench.. I sometimes need to 'convince' them to turn a bit more...
My theory is that maybe I did not spread enough arp grease on bolts/ washers... maybe not.. anyway they can't be really far from one another... 250# or torque is a lot of clamping force is you ask me!
Old 10-08-2007, 03:08 PM
ericwc's Avatar
ericwc
ericwc is offline
Where did the pictures go? I am very interested it seeing them... NEVER MIND...
Thanks
Eric
Quick Reply: Here are a few pics of my removed cab.
