Intake Manifolds ?
Old Oct 13, 2001 | 08:54 PM
otto's Avatar
otto
Intake Manifolds ?
Any auggestions on an Inatke manifold for my mild 390 ? I read the Edelbrock performer 390 was a dog, the performer rpm would probably be better but is kind of pricey, Weiand or Offenhauser maybe ? possibly the stock cast iron one could be used, its a 1965 casting if that matters.
What are you guys runnin on your FE's ?
Old Oct 13, 2001 | 10:33 PM
Ratsmoker's Avatar
Ratsmoker
Intake Manifolds ?
The performer isn't much better than stock, the weiand has no advantages that I have heard of. Its a single plane, but is a very low rising intake. Which equals less throttle response than the performer RPM and probably less power. I don't know much about the offy's. I would either go and find a 390GT or a 428 CJ intake or spend the cash on the performer rpm.
Old Oct 14, 2001 | 09:52 PM
FEina52F1's Avatar
FEina52F1
Intake Manifolds ?
I have a Weiand manifold and would not recommend it, except as a basis for a blower manifold.
I have an old Offy dual-port I put in the same class
I think the Edlebrock Victor is excellent - but not for a card on street engine - efi would be good.
The Edlebrock dual planes need to be slected according to desired usage.
I have a Holley X type manifold for my injection setup and it is pretty good - was pretty good with a carb but not a lot below 2400 rpm
The Edlebrock streetmaster was a similar design
In OZ and seeking 427block /428crank
Old Oct 15, 2001 | 08:38 PM
proeliator's Avatar
proeliator
Intake Manifolds ?
I run with the Edel RPM and can recommend it. Better to spend more money now then regret it later.
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE428 @ 400+ ponies , NP435 4-speed, custom suspension w lift, mud on black.
Old Oct 16, 2001 | 12:03 AM
karljay's Avatar
karljay
Intake Manifolds ?
The RPM is a pricey piece, but you should consider that the FE intake is very large and changing the intake makes more of a difference that probably any other V8 engine just because of how wide the intake is. The Performer 390 is supposed to be a alum version of the 390GT S code intake and not that great of a choice for performance apps.
Old Oct 16, 2001 | 02:45 PM
bsprowl's Avatar
bsprowl
Intake Manifolds ?
Look for an old Edelbrock F427. Those things work real well; I wouldn't take the time to install any of the other Edelbrock's unless I was building a low RPM motor for towing.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Oct 16, 2001 | 07:35 PM
otto's Avatar
otto
Intake Manifolds ?
I might keep the cast iron Ford piece, who knows
Old Oct 17, 2001 | 02:31 AM
FEina52F1's Avatar
FEina52F1
Intake Manifolds ?
Your back will appreciate you going for an alloy manifold :^)
Old Oct 17, 2001 | 08:27 PM
otto's Avatar
otto
Intake Manifolds ?
well I guess I'll have to spring for the performer rpm then
Old Oct 18, 2001 | 12:58 AM
gtex's Avatar
gtex
Intake Manifolds ?
Another vote for the Performer RPM! So far so good.
Greg
Old Oct 18, 2001 | 02:10 AM
FEina52F1's Avatar
FEina52F1
Intake Manifolds ?
I suggest the performer unless you want top end and can put up with the "gooey -er" low rpm. CI to weigth ?
Old Oct 18, 2001 | 09:13 AM
MattL's Avatar
MattL
Intake Manifolds ?
Old Dec 29, 2014 | 10:00 PM
Jspeake's Avatar
Jspeake
390 aluminum intake
I'm looking for a dual plane 390 intake.
Old Dec 30, 2014 | 01:06 AM
rockittsled's Avatar
rockittsled
Since this post was first started a long, long, long time ago, Jay Brown wrote a book testing over 40 intakes on 6 engines
http://ep.yimg.com/ca/I/yhst-4987827..._2271_32486863
Survival Motorsports News and Literature
There are a lot of popular myths about what works and what doesn't that gets exposed.
Old Dec 30, 2014 | 08:25 AM
Jspeake's Avatar
Jspeake
FE intake
Do you have a dual plane for sale.
12054925443
Thanks Josh Speake
zzbiker
18
Mar 25, 2018 02:03 PM
Keith Mitchell
Mar 8, 2017 04:48 PM
sledman3064
Jun 5, 2016 12:26 PM
RandallWhipple
Feb 7, 2015 04:58 AM
Purebeef
Jul 7, 2014 05:09 PM
