Sponsored by: Auxito
Zerk fitting conversion
Old Apr 30, 2002 | 05:52 PM
dabrnx's Avatar
dabrnx
Post Zerk fitting conversion
I just bought a 97 XLT and found out that there are onlt two zerk fittings in the front end. My joints are starting to look dry and I was wondering if the OEM fittings can have zerks installed and if so where I could get it done, or purchase.
DABRNX
Old Apr 30, 2002 | 07:32 PM
94van's Avatar
94van
Sometimes, the originals have a tiny hex-head plug in them, that can be unscrewed and zerks installed. If not, just run the originals and replace parts with greasable fittings when they are replaced.
The manufactures lay high claim to the new materials in tie rod ends and ball joints as to their lifespan. It's just preplanned parts sales in my book, hoping you'll get replacements at the dealer.
I prefer greasable parts.
[hr]
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old May 21, 2002 | 10:05 PM
amberski's Avatar
amberski
You can always use a needle tip to grease these joints. If you are worried about the hole the needle leaves, fill it in with a little silicone sealant. I bought my needle tip at Murray's for $3, it has a zerk fitting on the end so it can be attached right to your grease gun hose. ;-)
Old May 22, 2002 | 10:47 AM
MrBSS's Avatar
MrBSS
Amberski's solution seems to make sense, but on second thought would we really be getting the grease into the bearing surface? Any other opinions?
I know I'll be taking my 2001 F150 (with one!! grease fitting) in at 35,900 miles and asking for replacement on anything that's even a little loose!
MrBSS
Old May 26, 2002 | 01:10 PM
paveslave's Avatar
paveslave
Here's an idea... drill a hole in the center and put a self-tapping zerk in it, worked for me on a friend of mines truck.
-Ry
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3725&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3536&.jpg
Old May 30, 2002 | 03:51 PM
hdewe's Avatar
hdewe
I had the sqeaky pitman arm problem and used a grease needle. It worked immediately. I used the needle on all of my "zerkless" fittings. :-)
Old May 31, 2002 | 11:27 AM
LWM97's Avatar
LWM97
Old Apr 13, 2004 | 10:50 PM
dgrasser's Avatar
dgrasser
Greaseless, senseless
I read in a Haynes manual about what "94 Van" referred to.
The manual said to check for caps that can be removed and replaced with zerts. I just crawled under my truck tonight and several of the joints had "caps" on them that felt slightly raised like you could put a socket head on them to remove them. Haynes also said to ask at the parts place whether a straight or bent zert is the best for any specific location you are putting a zert in.
Has anyone put zerts in as opposed to replacing the entire joint.
Old Apr 16, 2004 | 08:32 PM
drighten's Avatar
drighten
I've done it in the past, but not so far with this truck. I am a bit leary of any sort of technique which could void the warrantee - I bought seven years. I do know that if at all possible, when they replace the joints, I will ask them to put in greasables. They probably won't, but since they will be paying for them, who knows?
Old Apr 19, 2004 | 09:05 PM
dgrasser's Avatar
dgrasser
I want to correct myself. After further observation of the joints, etc., I don't believe that any of them have caps. What I think I was seeing was just the other end of the bolt sticking out slightly. Sorry.
Old Apr 19, 2004 | 09:51 PM
HomerWinzlow's Avatar
HomerWinzlow
My Expy is due for lower ball joints right now at 50K. Ill be doing them myself in the shop if its real slow like it has been lately. I spoke with one of the regular front end techs and he says the average owner can count on lowers about every 50K and upper and lower at about 100K. If that holds true its not all that bad. The lowers are pretty reasonably priced and both arent too bad to replace yourself. 4X4 are somewhat more difficult however. He changed out uppers and lowers on an Expy 2x4 today in about an hour, hour and a half roughly. And he wasnt breaking a sweat either.
Old Apr 21, 2004 | 12:43 AM
hood's Avatar
hood
hdewe:
Don't know what year truck you have, but my 02 F150 pitman arm has 2 factory zerk fittings that i am able to grease at every oil change. Those were the only zerks i could find. And i found them by accident when i was under my truck looking at my starter.
-hooD
Snowseeker
Feb 28, 2015 09:59 PM
phillyfreak
Aug 25, 2011 12:13 PM
EXv10
Jun 18, 2009 11:15 AM
Gary A.
Mar 1, 2008 08:50 AM
Craig64
Nov 28, 2006 08:43 PM
