2006 6.0 L Diesel 4X4 -Zerk fittings to lube
I wrongly assumed that I had no zerk fittings to lube on my F-350 2006 6.0L Diesel 4X4. I discovered two zerk fittings, one on each side, today on the front axle. I'm now going to lube them. Does anyone know of any others? I will start looking my truck over carefully for more. Thanks.
At these locations:
1, 9, 11, and if you have after market ball joints, maybe them too...
<table border="1" cellpadding="3" cellspacing="0" width="70%"> <tbody> <tr> <th valign="bottom">Item</th> <th valign="bottom">Part Number</th> <th valign="bottom">Description</th> </tr><tr valign="top"> <td>1 </td> <td>3B410 </td> <td>Tie rod end (outer, RH)</td></tr> <tr valign="top"> <td>2 </td> <td>3A131 </td> <td>Tie rod end (inner)</td></tr> <tr valign="top"> <td>3 </td> <td>N800895-S301 </td> <td>Castellated nut, M14-1.5</td></tr> <tr valign="top"> <td>4 </td> <td>N642569-S36 </td> <td>Cotter pin</td></tr> <tr valign="top"> <td>5 </td> <td>3281 </td> <td>Adjusting sleeve</td></tr> <tr valign="top"> <td>6 </td> <td>3590 </td> <td>Steering gear sector shaft arm</td></tr> <tr valign="top"> <td>7 </td> <td>34798-S2 </td> <td>Lockwasher, 7/8</td></tr> <tr valign="top"> <td>8 </td> <td>380771-S301 </td> <td>Nut, 7/8-10</td></tr> <tr valign="top"> <td>9 </td> <td>3304 </td> <td>Steering sector shaft arm drag link</td></tr> <tr valign="top"> <td>10 </td> <td>3281 </td> <td>Adjusting sleeve</td></tr> <tr valign="top"> <td>11 </td> <td>3B411 </td> <td>Tie rod end (outer, LH)</td></tr> <tr valign="top"> <td>12 </td> <td>N602483-S301 </td> <td>Nut, M12 x 1.75 (off-road or heavy service option package only)</td></tr> <tr valign="top"> <td>13 </td> <td>3E651 </td> <td>Damper (off-road or heavy service option package only)</td></tr> <tr valign="top"> <td>14 </td> <td>3E653 </td> <td>Damper bracket (off-road or heavy service option package only)</td></tr> <tr valign="top"> <td>15 </td> <td>N606083-S426 </td> <td>Bolt, M12 x 1.75 (off-road or heavy service option package only)</td></tr> <tr valign="top"> <td>16 </td> <td>N811658-S426 </td> <td>U-Bolt, M10-1.5 (off-road or heavy service option package only)</td></tr> <tr valign="top"> <td>17 </td> <td>N606084-S426 </td> <td>Bolt, M12 - 1.75 (off-road or heavy service option package only)</td></tr></tbody></table>
diesel_dan
05-03-2017 04:26 AM
JohnnyAirtime
04-14-2016 05:43 PM
