axle code question
Old Oct 5, 2007 | 10:20 PM
jfoster5150's Avatar
jfoster5150
axle code question
Rearend went out in my 83 f250 found 2 different axles one is coded C7 on the door but cant find the ratio anywhere and the other one is C9 which I think is 3.55 limited slip but its out of a mid 90s 93 -97 crew cab will it fit with no major headaches? Im wanting the C9 if the ratio is what Ive found on the web(my axle is currently 31 floating rear ) the C7 is not a floating rear(hubs not extended out past rims) any thoughts on this would be appreciated..
Old Oct 5, 2007 | 11:13 PM
PLC7.3's Avatar
PLC7.3
Old Oct 6, 2007 | 05:09 AM
jfoster5150
Already found those and no C7 code listed on either.
Old Oct 6, 2007 | 10:56 AM
PLC7.3's Avatar
PLC7.3
Check out this page it may be of value....... you say 31 floating rear????
http://www.hemmings.com/mus/stories/...feature11.html
Old Oct 6, 2007 | 11:00 AM
jfoster5150
Yea the rearend I have in there now is a dana full floating code on the door is 31.... 373 gears
Old Oct 6, 2007 | 01:05 PM
jfoster5150
Latest update Im not going to be able to get the C9 coded axle so can anyone tell me what is the ratio on a C7 coded axle or am I miss reading the number
Old Oct 6, 2007 | 07:57 PM
mejonz's Avatar
mejonz
Red face
try this link for dana axles decode
www.onandoffroad4wheeldrive.com/dana_axle_ident.htm
Old Oct 8, 2007 | 02:09 PM
jfoster5150
latest update...Got the C7 axle from the salvage yard pulled the back off and counted teeth on pinion and ring gear and feed the numbers into a calculator from this web site http://www.differentials.com/calc.html and came up with 3.54 thanks for everybodys input especially Dave S...
JeffLee
Apr 26, 2013 08:50 PM
Jeff15061
Aug 19, 2012 10:58 AM
78_f150
Nov 1, 2010 01:38 AM
Rifleman7.62
Jun 28, 2004 08:35 AM
sleepysal
Sep 15, 2003 10:44 AM
