Carb spacer question...
Old Oct 5, 2007 | 09:49 PM
camperspecial65's Avatar
camperspecial65
I pulled my carb off my beast today...the spacer that the PCV goes to in the rear is plastic/bakelite...is that original or were the originals aluminum ??? Its a stock 352 2bbl ...
Thanks guys
- cs65
Old Oct 5, 2007 | 10:02 PM
bigblockford_390's Avatar
bigblockford_390
If I remember correctly my 352 was metal.
My 360 had a spacer under it that the heater hoses went through to help warm it up quicker. Needless to say that stuff is all gone now. I am almost positive that one was metal.
Jeff
Old Oct 5, 2007 | 11:01 PM
tbm3fan's Avatar
tbm3fan
All my cars, except the Cougar, have one of Fords 1" thick aluminum spacers under the carb. The Cougar has a very narrow spacer, straight from Ford in 1974, for use on medium rise manifolds in order to clear the hood. These do have a pcv fitting that starts round and narrows to a flute shape as used on a sax. I happen to have one of those spacers you are talking about that look like brown plastic/bakelite from a carb purchase on eBay. Will be finally getting rid of my '74 manifold with the egr outlet under the spacer and switch to a '67 390 2bbl manifold. The spacer used will be the aluminum one as clearance is not an issue and that keeps the carb farther away from heat.
Old Oct 8, 2007 | 02:00 PM
camperspecial65
anyone....I cant even find a part number for it and the illustration I see in my book is totally different to what I have seen on every truck Ive seen.
Let me know what ya guys think...cs65
Old Oct 8, 2007 | 06:22 PM
rusbukt's Avatar
rusbukt
My 352 2bbl has black plastic/bakelite also. Can't find any numbers around the sides.
Old Oct 8, 2007 | 11:55 PM
customcab66's Avatar
customcab66
my original motor had the plastic spacer in it as well
Old Oct 9, 2007 | 04:45 AM
jowilker's Avatar
jowilker
The spacers that came under the carb were for heat to the carb. It has a inlet and outlet with the heater hose connected. Many of those have been deleted over the years.
The engine needs to have the pcv working, so unless you have a carb with that port on it you may want to leave it. I had problems with my truck not starting after it had gotten hot and a 1" phenolic spacer resolved those issues.
I'd say it's a good think and leave it.
John
Old Oct 9, 2007 | 05:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by camperspecial65
anyone....I cant even find a part number for it and the illustration I see in my book is totally different to what I have seen on every truck Ive seen.Let me know what ya guys think...cs65
1965/67 F100/350 352 V8
1-C5TZ-9A589-C .. Spacer (1964/72 Ford Truck Parts Catalog: Section 95; Page 49)
2-C2AZ-9447-F .. Gasket = carb to spacer & spacer to manifold.
Illustrations in parts catalogs are for part number reference only. They should not be used to 'authenticate" what parts resemble on a particular vehicle.
Old Oct 9, 2007 | 11:34 PM
camperspecial65
Thanks Bill, I did leave it on...it has the feed for the PCV valve only...I was wondeering if the plastic one was an OE piece or if an aluminum one would be more likely ...the spacer is about 1/2 -5/8" thick...
I found the part basic number, but couldnt find the rest of it at all...weird I thought...thanks for the help Bill...
- cs65
al_wa
Dec 31, 2020 12:02 PM
DieselCamper
13
Sep 22, 2016 07:31 PM
boaterbob
Feb 2, 2013 12:03 PM
atomicjoe23
Mar 10, 2010 01:03 AM
td351w
Apr 14, 2002 12:41 AM
