carb spacer
Old Apr 1, 2002 | 03:41 PM
td351w's Avatar
td351w
carb spacer
What does a carb spacer do and should I put one on my 360? Thanks
Old Apr 1, 2002 | 05:27 PM
karlsd's Avatar
karlsd
carb spacer
A carb spacer theoretically does two things. First, it reduces the intake charge temperature by acting as an insulator between the intake manifold and the carb. A cooler charge is a denser charge, which will result in more power.
Second, it increases the velocity of the charge by effectively lengthening the runners. Higher velocity means better torque and throttle response.
I don't know how significant the effect is, but there is some effect. Spacers are also relatively cheap, so they're worth a shot. If your motor seems to be sluggish off the line, with poor throttle response, and you've already given it a good tune up and set the timing right, a 1" spacer would be worth a shot.
Old Apr 1, 2002 | 05:48 PM
BB's Avatar
BB
carb spacer
The insulator also helps reduce fuel percolation during heat soak.
Old Apr 2, 2002 | 05:56 PM
FEina52F1's Avatar
FEina52F1
carb spacer
Also
An open spacer can-
dampen the signal (intake pulses) thus leaning things out
reduce standoff ( reversion)
make changes in direction smoother
increase plenum volume
A 4 hole can
add stability to the flow below the carb
increase runner length
Old Apr 2, 2002 | 11:07 PM
chilly390's Avatar
chilly390
carb spacer
I recently dyno'd my 408w that will be going in a street/strip car. The carb spacers are definitely a great modification, it madee 5hp more at peak, but around 10ftlbs more torque from 4000 to 5800, that's a ton of performance for a $25 spacer.
Old Apr 13, 2002 | 10:55 PM
John_1953's Avatar
John_1953
carb spacer
I'm starting to work on my '53. It has what I think is a 352 in it. I know that it has a carb spacer that is hooked to the cooling system. Is that unique to any type/year of engine?
Thanks
Old Apr 14, 2002 | 12:41 AM
64f10's Avatar
64f10
carb spacer
benbuilder
WTB - Parts & other
Oct 22, 2015 09:42 PM
lemasters f100
Jan 20, 2014 10:50 AM
Ford_Six
WTB - Parts & other
Mar 18, 2010 04:28 PM
redneckfarmers
Jul 7, 2008 10:39 PM
beartracks
Jan 24, 2002 12:31 PM
