Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cutting cast iron plumbling?
Old Oct 6, 2007 | 07:54 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by tewferford
What is it, a little after 05:00 there? It's ok to have that second cup of coffee.
Been up since 3:30. **** insomnia!
Old Oct 6, 2007 | 09:36 AM
tewferford's Avatar
tewferford
Originally Posted by 70blue
It does appear to be around five inches. Luckily I have enough clearance to get just about any tool I want in there. I just have to make sure its well supported before the cut because it is vertical up to a point then goes horizontal overhead for two feet. Cutting about a three foot section off. I bet that would feel good coming down on my head. I could cut the horizontal run and save a pvc elbow but I am gonna cut where it is easiest for me to work with clearance wise. Only have one good arm at the moment..
Get some help! That pipe is going to weigh a bunch. Make your horizontal cut first, then the vert. If you can't get help. Tie off the vert line so you can ease it down after your sec. cut.
Old Oct 7, 2007 | 07:53 AM
daddio360's Avatar
daddio360
I once had a brand new $30.00 hole saw break the first time I used it...snapped off right where the mandril attatches...GRRRRRR!
Old Oct 8, 2007 | 07:10 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from GC. This type of tech thread is better to reside in the workshop forum.
Old Oct 8, 2007 | 08:15 PM
sierraben's Avatar
sierraben
Mr. Miyagi use karate chop and cleanly breaks pipe.
Danielson says holy carp, how you do dat?
Mr. Mayagi says don't know, first time.
However, like before, I'd suggest using a pipe snapper.
Probably take less than a minute or two.
And don't forget to wear gloves and goggles; dust mask optional.
Old Oct 21, 2007 | 03:28 PM
2pd519's Avatar
2pd519
do your self a favor and rent a snap cutter, i got two of them.... it really is the best way to cut the cast iron soil pipe. trying to cut cast iron soil pipe any other way is a big pita.
Old Oct 24, 2007 | 04:28 PM
oldgoat49's Avatar
oldgoat49
I've used a recip saw with both cheap and good blades. The cheap blades didn't last and just made it harder. A good blade went through it without much trouble. Just don't get in a hurry and force or pinch it and you should be ok. Also used a cutoff wheel on my grinder and it did OK but not as straight a cut. For me I don't like renting plus the time to go get it and bring it back in time, but that is just my pref.
Raptor119
Sep 12, 2012 09:03 AM
LARIAT 85
Appearance & Dress-Up
May 19, 2007 08:22 PM
4wheelinbroncos
31
Oct 31, 2004 10:00 AM
Redone
Feb 19, 2004 08:50 AM
John1201
Aug 5, 2001 11:34 AM
