Exhaust setup
Old Jan 7, 2004 | 01:06 PM
Redone's Avatar
Redone
Exhaust setup
I was wondering what size diameter pipe I should have for a single out? Or if dual, what size? Does anyone have any pictures of either setup? How should I run the pipes? How much more in performance can I realistically expect from this type of upgrade?
Also, I'm using the stock cast iron manifolds on my truck. I can cut and weld pipe all day but I cannot justify the cost of headers right now.
Thanks.
Old Jan 7, 2004 | 08:45 PM
garypettengill's Avatar
garypettengill
I acutally went to NAPA a few years ago and bought a complete system for my '77 shortbed with a 400. Not much to it, a "y" pipe to bring both sides to the inside of the right frame rail, the muffler, and then the tail pipe to exit behind the right rear tire. Mines an F150 4X4 so no cat is required.
Old Jan 8, 2004 | 03:30 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Engine? Any mods?
Old Jan 8, 2004 | 03:37 PM
Redone's Avatar
Redone
Sorry, it's a stock '79 351M.
The only thing that has been done to it are those ideas suggested by Bubba - his website (man it's amazing what a good tune up and a little tweaking can do).
Old Jan 8, 2004 | 04:23 PM
BlueOvalboy25's Avatar
BlueOvalboy25
I have a 1980 ford f150 with a 400 and i run dual 2 1/4 and it works very nice. I also put glass packs on it .
Old Jan 8, 2004 | 05:46 PM
79_250RangerLariat
I'm running stock manifolds with 2 1/4" duals, turbo mufflers on my 78 bronco. Stock 400 and it works well.
My 79 250 with a slightly modified 400 has headers, flowmasters and 2 1/2" duals. Works very well and sounds good too
Old Jan 8, 2004 | 09:20 PM
Matts72's Avatar
Matts72
Don't go any biger than 2 1/4" duals or 3" single pipe.
I have always liked the dual exhaust that exits right in front of the rear tires, thats ford style, or the ones that exit at the rear quarter panel, corvette style.
I would suggest that if you tow anything, or do a lot of close backing up, that the bumper exit pipes are not a good idea.
Old Feb 18, 2004 | 03:17 PM
Countryboy7x's Avatar
Countryboy7x
I would start with a good set of headers. Follow it up with some free flowing exhaust pipe 2 1/4"-2 1/2" works good with the 351M/400. Mufflers are your choice, Most will help with sound control, and give you some extra ponies. Finish that exhaust system with some nice stainless steel tips, and you should be done. Here is the system that I am running on my 1978 F-100 Custom with a built 400 V8.
Hedman Headers.
2 1/2" Exhaust pipes.
Dynomax Bullet racing mufflers.
4" Stainless Steel tips.
Adam Hanson.
Old Feb 19, 2004 | 08:50 AM
jmalecek's Avatar
jmalecek
I know this doesnt match your engine....but on their web site it doesnt give all the products. It's the same price, I was looking at it for my truck, 77 f150 w/400. It'll give you an idea, or maybe order the catalog.
Jamie
www.summitracing.com part# SUM-CBJJ119
jayro88
Oct 13, 2012 08:59 PM
Splatts
Oct 2, 2011 03:20 PM
scooter1986
Apr 2, 2007 07:17 AM
Stampede
Sep 30, 2003 05:28 AM
Stampede
Sep 30, 2003 05:25 AM
