Schaeffer ATF?
Old Oct 8, 2007 | 02:05 PM
jtharvey's Avatar
jtharvey
The transfer case takes the same 204SAT fluid that your transmission uses Rear end takes a 75W-140. Front diff takes a 75W-90. (I just changed these a couple weeks ago, so the info is pretty fresh.) For oil you can either run a 15W-40 or a 5W-40, whichever you prefer. Personally I run a 5W-40 year round...well except for this last change and I didn't have enough 5-40 so went with the 15-40.
I would check with the home office to see if you have a sales rep in your area. Call Toll Free: (800) 325-9962
Old Oct 9, 2007 | 02:57 AM
Mach1's Avatar
Mach1
JT-you using the S9000 aren't you, $.25 a qt difference, Yes I have heard they put in an additional 1% ester base in the CJ stuff..
My wife got into my Citrol and uses it to clean everything..I walk into the house and it smells like the shop..AH sweet home....
Old Oct 9, 2007 | 06:23 AM
white Buffalo's Avatar
white Buffalo
Originally Posted by Mach1
Did your S9000 come in Generic labeled bottles? Or did yours have the nice green labels,
No bottles/containers - came out of a 55 gal drum
Old Oct 9, 2007 | 10:14 AM
jtharvey's Avatar
jtharvey
Typically yes. I had some 7000 in the garage when I needed to change my oil last, so that's what I'm currently using. I will go back to the 9000 though on my next change.
Old Oct 10, 2007 | 01:48 AM
Mach1's Avatar
Mach1
WB, have you seen the new 1 gallon container/label, they are grey and look generic type..I guess they dont have the new ones printed up..
JT, I hear ya, I thought there was some sense to the 7000 vs. 9000
ToMang07
56
Dec 11, 2015 04:02 PM
87&97Aerostrar
Aerostar
Mar 15, 2015 10:20 AM
Extreme Dimensions
Vendor Specials, Discounts, Product Announcements & Group Buys
Jul 3, 2014 11:21 AM
kjjr20
May 3, 2014 06:50 PM
