swap out
Old Oct 5, 2007 | 07:03 AM
bigdaddyjames70's Avatar
bigdaddyjames70
Smile swap out
hello all, first time user. I just bought 1970 f100 w/ a dead 302 and a good 3 spd.tranny I've got a line one a 85 elec.feed back[junk] carbed 302 w/ aod trans I thinking of puting in . I will be replacing the intake & carb with the old style orignal hope it works!!
Old Oct 5, 2007 | 10:25 AM
airharley's Avatar
airharley
Welcome to the board.
Are you swapping the AOD in as well? You might have to settle with swapping the carb for the time being. I think the intake bolts patterns are different, but don't take that as 100% correct since it has been a while since I ahave played with one. However, since the two 302's have different harmonic balancer weights, 70 28oz & 85 50oz you wont be able to swap the flywheel to the new engine. So if you are a die hard for the manual you will need to rebuild the '70 302 while you swap in the other drivetrain.
Old Oct 5, 2007 | 04:04 PM
vinlin95's Avatar
vinlin95
Smile swap
put the same engine in when i built my 302 ranger. intake worked fine & carb worked with the kickdown off the e carb.
Old Oct 8, 2007 | 08:19 AM
bigdaddyjames70
yes i'm going to use the aod. what about the axle ? will I have to change them out . the 70 has 9" the 85 is unknown. I going to use a floor shifter out of a bronco 2
Old Oct 8, 2007 | 12:26 PM
jowilker's Avatar
jowilker
The 85 setup will be wider than the 70. 86 was the last year for the 9" but some 8.8s could have been installed by then.
John
Old Oct 8, 2007 | 09:45 PM
vinlin95's Avatar
vinlin95
swap out
i had 373 gears in my ranger & the aod worked real good with those gears. i'd check to see what your 9 inch had in it & go with it if you can.
92ford15089
Engine Swaps
Jun 6, 2011 09:05 AM
CDF302v8
22
Jan 5, 2011 11:22 AM
Bossman77
Jan 2, 2011 04:38 PM
