92 f150 efi 302 conversion to 351w carb
I did this for my 1987 f150 and now I plan to do the same thing to my 1989 f150. So far I know you will need the older electronic ignition distributor, a fuel pressure regulator or low pressure fuel pump, change the fuel line near the end to fit to the carb. Its not very hard, just kinda time consuming cause you will run into things that I haven't and vice versa.
What kinda trans you got? That is the most important thing right now.
Rebel 84
05-17-2015 07:06 AM
07f250diesel
07-10-2014 08:04 PM
Mikonoclast
05-12-2002 09:59 PM
302, 351w, 58, 92, carb, conversion, convert, efi, f150, ford, intake, lowerupper, stock, troubleshooting, truck
