My brother has a 99 f-250 SD with a V-10 in it.. an I have a 04 f-250 SD with a 6.0L PS in mine.... his has a helper spring on the rear of his truck and my truck don`t... can I put OEM.. helper spings on my truck?? if so can any one help me with part number...I would like to put them on my truck to look like OEM. there is holes in the frame for the mounts...thanks
This isn't something that is commonly done. The "helper" springs don't really help much. I've had 4000 lbs in my bed, and they weren't down on the pads... yet!
The other thing is that they are only serviced with the entire spring assembly, they are not an addon part from the dealer that I know of. A spring shop may be of more help. You should be able to get the bracket/pads from the dealer and bolt them on however.
Oh, and we were all just holding out on the info to make you nervous....
