Sponsored by: Auxito
Add On Keyless entry
Old Oct 14, 2007 | 03:16 PM
chapinjohn's Avatar
chapinjohn
Big Red,
I know this works for a 95 Ranger. He means to
turn the ignition key from off to on several times.
The door latches will lock then unlock after, well
four times for the Ranger.
Old Oct 14, 2007 | 03:24 PM
bigredneck47240's Avatar
bigredneck47240
thats what i thought i just wasnt sure man im out of it today for some reason
Old Oct 14, 2007 | 08:09 PM
IN2FORD's Avatar
IN2FORD
I looked at the plugs you spoke of. They don't have anything to do with what we need. I looked again and I do not see the plugs we need. It's looking like Ford did not wire all trucks with remote entry. I have a buddy of mine that has a connection with Ford. He is going to check in on what our options are. As soon as I know I will report back...
IN2FORD
Barry
Originally Posted by chapinjohn
Looked under the dash, I don't see what you describe
I do see two unused gray male plugs, one is directly
under the "Hood" pull. They both are about 1" x 1/2" and this one has
two prongs. The other is to the right (behind what I think
is where the shop computer connects, its black) and
its an unused five prong male connector. What are they for?
John
2000 150XLT 4.6L
Old Oct 16, 2007 | 07:42 PM
83stepside32784's Avatar
83stepside32784
when i bought my 99 F-150 it came with 1 key and no clicker so i went to the junk yard and got one i cycled my ignition from off to on 8 time ending in on position ,doors locked then unlocked i pressed lock on the remote turned off ignition ,and it programmed my clicker to work, it works flawlessly
Old Oct 16, 2007 | 07:46 PM
bigredneck47240
do you have to do it fast? if you do then how do you do it when the push key lock lever
Old Oct 17, 2007 | 10:01 AM
KingRanchMan02's Avatar
KingRanchMan02
You have to do the key on/key off eight times in 10 seconds. Then after the truck acknowledges with a lock/unlock signal, you have 20 seconds to push a button on the key fob to program it. Good luck!
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
260karl
Sep 2, 2015 05:32 AM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
dukman22
Feb 5, 2007 07:48 PM
