Sponsored by: Real Truck
Traction Control
Old Oct 5, 2007 | 08:29 AM
johnnysF350's Avatar
johnnysF350
Originally Posted by krewat
Except that my '97 Cougar gets up and GOES - it does retard the power from the engine slightly, but not enough for it to "fall on it's face"... far from it - if I keep applying more and more go-pedal, it will eventually overcome the rear brakes and spin the wheels anyway...
Maybe the CV has a 3-channel setup?
To find out for sure, we'd have to look at a wiring diagram for the '08 SD - anyone with an EVTM for the '08?
I don't know what the issue was with the CV but all I can tell you is that it did not work the way yours does and it left a bad taste for me. It was downright scary if you tried to pull out and didnt give yourself tons of room. Granted it worked better if you were accellerating in a straight line, but try pulling out of a parking lot entrance where you had to make a turn and it was horrible. I think maybe they had the system programmed to aggressive back then. Maybe they are much better now.
rollerderby2005
Apr 27, 2017 08:26 AM
PwerStroke99
Feb 22, 2017 06:31 PM
5 Star Tuning
2015 - 2020 F150
Nov 29, 2016 04:45 PM
Jmatthews
6.7L Power Stroke Diesel
Apr 16, 2016 10:38 PM
pinestar
2009 - 2014 F150
130
Jan 3, 2012 02:08 AM
