Oil Pan Clearence Fe engine
Old Jan 7, 2002 | 01:15 PM
1QUICK75's Avatar
1QUICK75
Post Oil Pan Clearence Fe engine
Can anyone point me in a direction to get an oil pan for a 75 F150 390 that holds at least 6 & 1/2 quarts and will clear the crossmember. Tried Milodon & Moroso deep sump pans but neither clear, need a pan that is wider on sides and maybe front, but not deeper.
Thanks
Michael
800-929-6178
Old Jan 7, 2002 | 04:03 PM
dinosaurfan's Avatar
dinosaurfan
Michael, have you looked at Canton ? They make some very nide trays and pans for FEs. They also have on available a wide front sump pan with rounded corners that fits the TwinIbeam suspension that trucks have. DF
Old Jan 7, 2002 | 05:57 PM
FE427TP's Avatar
FE427TP
DF are you sure it will clear? I know B.S. Campbell had to cut his crossmember some to get it to clear in his 72 when he put the 428 in
Old Jan 7, 2002 | 11:08 PM
dinosaurfan
Yes, I'm sure it clears. Canton heard from guys like Campell and modified the pans design to allow a problem free fit. Do be sure and tell them it is going in a truck, you don't want to get the car-style pan by mistake. DF
Old Jan 9, 2002 | 11:30 PM
390fe's Avatar
390fe
Some of the FT truck engines had high capacity pans that held nine or ten quarts. They might be worth looking at, if you can find one.
Jason Kendrick
Old Jan 10, 2002 | 11:56 PM
FE427TP's Avatar
FE427TP
