New F-100
Old Oct 2, 2007 | 02:42 PM
Weelspin's Avatar
Weelspin
Red face New F-100
OK.... 1970 isn't new.... But this is what I got. A 1970 F-100, Carolina Blue, 3 sp (2 sp with a granny??) with a 351 Cleveland. What all do I have? Bolt pattern and tranny model etc would be awesome. The shift pattern is wierd... well to me. Left and down is 1st (granny), middle and up is reverse, right/up is 2nd and right/down is 3rd. 2WD and in good shape. Lemme know?
Pep
Old Oct 2, 2007 | 05:42 PM
Freightrain's Avatar
Freightrain
That is a regular three spd tranny, but it sounds like someone put a floor shifter on it. It's the same tranny they use for the column shift, but usually after the column gets worn out and don't shift well, they put a floor mount shifter on it.
Old Oct 2, 2007 | 09:04 PM
Customcab's Avatar
Customcab
Post your vin data and we can decipher your questions. Great to here another truck is with a good home. Has the shift lever been transfer from the column to the floor?
Mitch
Old Oct 2, 2007 | 10:22 PM
Weelspin's Avatar
Weelspin
Yep... it's on the floor and I had first, "What the hexx!" moment today. Wouldn't shift. Lever would move, but no gears. Crawled up under and tightened 6 bolts and 9 nuts. Found a LOT of loose stuff. Looks like some used a universal shift kit and made it work. I'm gonna need a few extra washers..... And a LOT of locktite. I saw where they cut the hole for the floor shifter too... makes sense. What about axles and bolt pattern? I'll get the VIN up here soon...
gl0116
15
Feb 1, 2014 01:01 PM
John in Vegas
New Member Introductions
Sep 25, 2013 03:07 PM
Weelspin
Aug 19, 2007 06:01 PM
bengraudin
Jun 25, 2007 09:55 PM
tnwalker01
Engine Swaps
Dec 22, 2005 09:00 AM
