Fuel filter wire thingy
Old Oct 1, 2007 | 11:49 PM
Chorizo520's Avatar
Chorizo520
I changed my fuel filter and was looking in where the filter came out. At the bottom of the resevoir is a 1/2 circular wire. Looks like part of a springy clip about as round as the filter. I could wiggle it around a bit and was tempted to pull it out but feared I would break something.
Question: Any idea what it is? Should it be 1/2 circle or is it broken?
could this be am MPG problem?
Thanks
Old Oct 1, 2007 | 11:57 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I believe you are talking about the fuel heater element. Don't mess with that if that is what you are talking about. The next thing you know you will blow a fuse that will give you fits with the truck.
Old Oct 1, 2007 | 11:58 PM
Red Monkey's Avatar
Red Monkey
Don't know for sure...could it be your fuel heating element?
I'm sure someone will know.
Old Oct 2, 2007 | 02:51 AM
ryaneverk2's Avatar
ryaneverk2
Sounds like the fuel bowl heater element to me, also.
Like Mike warned, if that thing breaks and short circuits, it'll likely blow the fuse of the circuit it's on... which also protects the PCM relay.
Old Oct 2, 2007 | 09:13 AM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Ditto............
Old Oct 2, 2007 | 10:05 AM
Chorizo520's Avatar
Chorizo520
Should it be attached at both ends? Because one end is not and you could wiggle it...
but I wont.
Macs1964F100
Jun 24, 2014 10:05 AM
BROWN DOG KTM
6.4L Power Stroke Diesel
Jul 6, 2012 05:10 AM
lechonera
Sep 28, 2010 01:19 PM
bduemig
13
Aug 16, 2010 03:17 PM
SmOkIn(EM)OUT
Oct 28, 2009 08:56 AM
