Insturment cluster
Old Nov 30, 2007 | 09:33 PM
  #31
Mil1ion's Avatar
Mil1ion
Originally Posted by bluey
hi,
i've read all the posts above and i still have a question: i have a 1976 f250 whose gauge cluster turned to dust. i threw out the old pieces including the colored circuit board so i don't know what color it was. i got a cluster off ebay before i knew there were two pin sizes, oof! my question is, if i got the wiring diagram for both trucks, can i splice the newer cluster in? i realize the high beam bezel is in a different place, but do you all think the gauges will work?
thanks in advance!
Gauges cluster = 18 pin
Warning lights cluster = 14.
They really can't be adapted to each other.
Which one was in the truck ..gauges of warning lights ?
There are plenty out there for you to do it right.
If you want to upgrade, you need the complete harness.
Old Dec 1, 2007 | 07:40 PM
  #32
bluey's Avatar
bluey
gauge cluster swap update
i found my old piece of circuit board. unlike what the junkyard told me (that it would be blue or green), it is a red/pinkish color. 2 rows of 7 copper conductors. part # 06TF-10C956-C1.
i'm still thinking of splicing a 9 pin connector to my wiring loom since these 7 pin units never pop up on ebay. does anyone know the positions/colors of the two wires i'll need to leave off?
if anyone knows any good sources of these gauge clusters, let me know, thanks!
Old Dec 1, 2007 | 08:25 PM
  #33
Mil1ion's Avatar
Mil1ion
Did you not see posts #12 or #20 in this thread ?
There are 14 pin and 18 pin connectors
Not 7 & 9 .
It will NOT work... they have a different make up in circuitry.
I have a few in my garage.
You need a 14 pin cluster and printed circuit ...for warning lights correct ?
Or an 18 pin wiring harness so you can have gauges ?
Old Dec 1, 2007 | 09:04 PM
  #34
ChaseTruck754's Avatar
ChaseTruck754
He needs a 14 pin - he was just going by 1 row - vs. total number...
Old Dec 2, 2007 | 02:16 PM
  #35
bluey's Avatar
bluey
looking at my circuit panel and the bits of plastic left, i can see i had the two idiot lights and two gauges...14 pin connector, just like mil1ion said!
thanks to those who have responded; now i know what i'm looking for!
Old Mar 27, 2008 | 09:20 PM
  #36
freebird01752's Avatar
freebird01752
Hi Guys,
I found a 100 mph cluster real cheap. It has the blue circuit and my has the pink / red. Is it possable to swap the circuit panels? if itis do i swap the regulators also? Not really concerned about the high beam light and both have the idiot lights. This is in a 79 F100.
Thanks,
Steve
Old Mar 27, 2008 | 10:33 PM
  #37
Mil1ion's Avatar
Mil1ion
Post the number on it and note: it has to be gauge to gauge not warning lights to gauges.?
Old Mar 28, 2008 | 01:43 AM
  #38
bucks77ford's Avatar
bucks77ford
If I were to try an upgrade from idiot lights to guages, I wouldn't mess around with asking how and trying to switch from 14 to 18 pin connector and what not.....I'd just get some good mechanical gauges since they are more reliable than idiot lights and factory guages and mount them under the dash. JMHO.
Old Mar 28, 2008 | 12:46 PM
  #39
Mike's 77's Avatar
Mike's 77
Talking
Originally Posted by ArcadeTom
LOL
The 100 MPH speedo only does something for your ego (mine has it but will never-ever hit 100 unless dropped from a C-130). Think of it in a manner similar to the marketing people making the newer cars...my new company (chevy) truck has a speedo that goes to 140 MPH. It is LIMITED at 96 and strains to get there! LOL But it does get noticed when people get in and see a 140 MPH speedo.
I've got a 100mph speedo in my 77 f150 supercab longbed with a 400 and usually top out on the freeway around 85mph but I have touched 100mph once! lol just thought I'd share that it's possible....just not reasonable on gas lol
Old Mar 28, 2008 | 12:51 PM
  #40
Mike's 77's Avatar
Mike's 77
I'm just wondering what the idiot lights are? I'm not sure if it has been explained yet or not. But could someone please explain to me the difference between the idiot lights and gauges? thanx
Old Mar 28, 2008 | 12:59 PM
  #41
Mil1ion's Avatar
Mil1ion
Warning lights for Oil Pressure and Temp and Charging.
When oil is so low it can't keep the SU from completely grounding out, the Oil light comes on.
Same for coolant temp light.
Charging light is different
The cluster with warning lights has 14 pin
the gauges cluster has 18 pins and a slightly different wiring for the ammeter.
Old Mar 28, 2008 | 01:19 PM
  #42
projectbad78's Avatar
projectbad78
hey guys, for the leds, go to ebay and put in "194 led" and there are a bunch that pop up...theres on where you get 10 bulbs for $10 ....sounds like a good deal to me
Old Mar 28, 2008 | 01:28 PM
  #43
Mil1ion's Avatar
Mil1ion
LED's won't dim though.
Starry ..starry... Night
Old Mar 28, 2008 | 01:39 PM
  #44
projectbad78
would they really be that bright?
Old Mar 28, 2008 | 01:47 PM
  #45
rsalter66's Avatar
rsalter66
well give it a shot and let us know PB78
You can be our Test Pilot????
"NO PARACHUTES ALLOWED!"
