Motor heating up quickly
Old Oct 1, 2007 | 08:45 PM
1980FORD's Avatar
1980FORD
I have posted several questions in this thread and recieved great advice so I hope my luck hold out on this. I just installed a remanufactured 300 from a company called proformance in my 1980 F150 w/T-18 manual. Installed a comp cams 260 cam kit, Offy dp intake, holley 390 carb, a new DSII distributor, coil, etc. If it bolted on I replaced it. I fired it up for the first time today and it ran great. The only thing that sort of concearned me was it heated up FAST. I only ran it for 5 minutes or so just to adjust the idle speed on the carb and it heated up enough to open the thermostat (I know because I have a new after market gauge I was watching) The intake was also very hot. Now I bolted it to the stock exhaust manifold so I expected some heat but man!! I have NOT set timing exactly yet, nor hav I tuned the carb. Is this heating up, both of the motor and intake, normal? Thanks for any help. Now that it is running again, I can finally set up my gallery with some pics!
Old Oct 1, 2007 | 10:29 PM
kotzy's Avatar
kotzy
Get the timing set where it belongs and see what happens, late timing make them run hotter. kotzy
Old Oct 2, 2007 | 05:31 AM
srercrcr's Avatar
srercrcr
You think the intake is hot? Try the exhaust side! Mistimed 300s have been known to exhibit a cherry-red exhaust manifold. I'm puzzled why it ran so good though.
Old Oct 2, 2007 | 06:13 AM
acheda's Avatar
acheda
For the record, all air should be burped out of the coolant and you want to avoid prolonged idling until the cam & lifters get their initial wear-in. These are important things to do for the initial running of any rebuild. I agree with the previous comments, but will add that new rings can create a lot of heat during their initial run-in. This symptom slowly goes away during the first few hundred miles.
Aluminum conducts head much better than cast iron, so the intake manifold will be hotter due to conduction of exhaust heat from the heat riser. This will give you better warm-up in the winter. There may be too much of this effect during warm weather. I plan on running the same intake with EFI exhaust, so I will have the opposite problem (no heat riser) and plan on adding a water-heated heat riser in series with the heater hose so that I can shut of both with a water valve during the summer.
Old Oct 2, 2007 | 09:16 AM
1980FORD's Avatar
1980FORD
Thanks for the replys. I ran out of time yesterday but am planning on setting the timing today. I was trying not to run it to long because of the break in procedure of not letting it run at the same rpm for too long. I was a little amazed myself at how good it ran too. It was SMOOTH! No misses, backfires, nothing. Thanks for the help.
Kittycat1979
New Member Introductions
Aug 23, 2016 11:35 AM
AbandonedBronco
28
Jul 24, 2014 03:02 AM
harrelle
Jun 30, 2013 09:02 PM
jdog_kustoms
Dec 12, 2009 03:57 PM
muscletruck7379
General Automotive Discussion
Oct 10, 2007 08:24 PM
