OBA installed...no difference in boost?
Old Oct 1, 2007 | 08:59 PM
Alpine6's Avatar
Alpine6
I have an ATS Housing. On 80 with red line attached, I get about 25-26 at WOT. Only about 27-28 psi on 140 smoke. With the line unplugged, I got like 30+ psi and quickly stopped and reattached.
Old Oct 2, 2007 | 01:52 AM
crack's Avatar
crack
im going to make a little leak detector first for sure. I tightend my one IC pipe up so much Ive crushed it...is there anywhere to get new ones ha?
Old Oct 2, 2007 | 09:50 AM
ron's power stroke's Avatar
ron's power stroke
witch pipe got crushed?? can it be fixed with a stretcher (not sure what it is called) from an exhaust shop??
Old Oct 2, 2007 | 10:06 AM
crack's Avatar
crack
the hot side, im pretty sure I can fix it with the handle of a pipewrench and a hammer (usually how we fix rods on the drill) or something to that effect. then maybe ill find something the same diameter and put it inside to prevent crushing it while I clamp down. I need to find a little pressure regulator somewhere, as I dont have a lowes or a home depot or anything like that at my dispense
Old Oct 2, 2007 | 12:19 PM
ron's power stroke
that sucks i have the other side and would have been glad to send it..my driver side has a hole in it from the brass elbow for the power steering hose...i use a presure reg for a air compressor.. does any one you know you one that you could barrow??
Old Oct 2, 2007 | 12:45 PM
crack's Avatar
crack
the ol man has a little tank he brings the to drags I might be able to snag it off there. quick question...say you fill it up to like 40psi....are you going to blow your headgasket haha?
Old Oct 2, 2007 | 01:24 PM
ron's power stroke
lol you should be ok.. but 20 to 25 is all you need to hear a leak...be careful..I went to 40 and the detector popped off and just about took my head with it..it was a loud POP..scared the crap out of me......
Old Oct 2, 2007 | 01:34 PM
crack's Avatar
crack
haha..I'll see what I can do
sufferingant
May 21, 2011 08:50 AM
viperbluelx
16
Nov 3, 2009 06:03 PM
gasgrunt88
Jul 16, 2009 10:47 AM
gasgrunt88
20
Jul 8, 2009 05:28 PM
STAGED
16
Jun 5, 2007 04:36 PM
